7 members (Image, +8Rich, How, Jens, jbk, Graham, G4FUJ, Deejay), 310 guests, and 90 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,428
Button #545288 28/11/18 06:43 PM
Whilst you have your wire brush out, check the axle breather hole is clear. It's a small 1/8" hole on one of the Salisbury axle tubes.
If it's blocked with paint or dirt, the axle may pressurise and oil leak past the seals onto the brake shoes.
Arwyn
Button #545311 28/11/18 08:21 PM
Button: looking forward to seeing you in Sun Valley, assuming I make it through the Colorado snows to the start in Newport Beach!!!
Calypso Red: when looking down on the axle the nipple is at 3 or 9 o'clock and the worm hole is on the opposite side at either 9 or 3 o'clock. It can take a lot of grease. I live off dirt roads so get a great deal of crud down there, I use a solvent spray to clean the area.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Button Offline OP
Originally Posted By Calypso Red
Originally Posted By britmog
My 1994 +8 has the grease nipple and hole for the "worm"of grease to exit. Just serviced mine ready for the Morgans Over America rally in May.
Hi Britmog, I have a 1994 +8 and although I have found the grease nipples on the rear axle just behind the back plate of the brake drums I have never found the "worm" of grease holes dispite persistent searching. Can you describe for me exactly where these holes are on the axle? Thanking you in breathless anticipation......
I clean the little hole with a small drill bit.
Button
