5 members (SteveT, Luddite, Gordon D, RedThree, TBM), 394 guests, and 96 robots.
Sagging Hood
Topics49,859
Posts837,479
Page 8 of 13 1 2 6 7 8 9 10 12 13
0
I have to say, the 'new design' MMC rack is a piece of jewelry. The clamps are elegantly designed and machined.
'17 M3W:
'08 Ural Gear-Up
Thankfully CRS did not happen
Rodger
2004 Plus 8 (wife's)
Hi Rodger!
Is this the new design or is it a one off solution!
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
new design
Rodger
Does it hinge up or does it need to be removed to access the boot?
you have to remove it. Really quite simply. The is a pin (you can see it on the last picture immediately behind the roll bar) and a spring clip cotter key below. It then slides backwards to come out. So if you were using it for a long trip, the only stuff you would want in the boot is things you would access at the end of the day. Or you might stash your tools and spare parts in the boot.
I have noticed the pictures make it look like it conforms to the curvature of the body, but it is flat.
Rodger
Thank you for your explanation!
Some positive changes to the old version but still far away from practicality.
Hannes
well, yes, in that whenever I need in the boot, I have to take it off, but for a several day trip ample room to carry things. I also view it as a bit of security in that I do not worry about the boot flying open - LOL
Rodger
Did they provide any installation instructions?
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
no, it was installed at the factory and the dealer showed me how it comes off to access the boot. If you were to install the whole thing as an add on it would be really straight forward. there is a two piece part that bolt/clamps to the roll bar. If I were doing it, I would leave those semi loose to line up the parts that insert off the rack and then level both side to side and front to back, before tightening
Rodger
