7 members (MATTMOG, John Winn, OZ 4/4, How, IcePack, mph, John07), 303 guests, and 40 robots.
John V6 70
DaveW 66
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,992
RedThree
#550142 26/12/18 09:56 AM
PAUL21 Offline OP
Can anyone suggest a solution, I turn the key in the ignition. but the lock symbol won’t go out ,This is my first time on the forum,
Merry Christmas ,
Paul21
Have you lost the little bit in the key for the immobiliser.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
If you have a spare key, try that. If it works then maybe you have lost the immobiliser chip in the key.
"Hasta la victoria siempre"
PAUL21 Offline OP
I have tried both keys , the spare is brand new and unused!!
I don't know if you are a member of the MSCC, if you are then in the December issue of Miscellany, Dave Wellings has a piece about keys and immobilisers, worth a read it could be related to your problem
Try charging the battery. One member on here found the immobiliser a little finicky about less than optimum battery volts.
Thread here
Can you give us more details on what the car is please.
Later cars have an immobiliser ring in the lock.
If the battery is low it may not work well.
As said search for the Dave Wellings thread on this
2025 MG ZS EV aka Trigger
Here's Dave's thread on the subject
http://www.talkmorgan.com/ubbthreads.php/topics/539514/1
There is an issue with later Plus 4's. Try taking the key out of the ignition then rub the fob against the ignition barrel. This is usually sufficient to get the chip close enough to the induction loop to disable the immobiliser. Once the light goes out you have 30 seconds to insert the key and start the car.
Regards
Alan
AP08 MOG
Put the key in the ignition Paul. Don't turn it.
Put a battery conditioner on and the immobiliser will disarm in a few minutes.
PS - if my theory holds true, your Plus 4 will be 2016 onwards with an autophoretic coated chassis........
PAUL21 Offline OP
Thank you all for your help, l have had the car on a trickle charge which said the battery was charged, but when I used an additional jump start the car started immediately and with all keys
Beautiful day in Edinburgh, now can take the car out ,,but will not turn engine off till I return,
Thank you all again
