SORN
New
Topics48,374
Posts813,504
Members9,215
Posts: 5 |
Can anyone suggest a solution, I turn the key in the ignition. but the lock symbol won’t go out ,This is my first time on the forum, Merry Christmas , Paul21
Posts: 187 Likes: 2
Posts: 187 Likes: 2 |
Have you lost the little bit in the key for the immobiliser.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
Posts: 490 |
If you have a spare key, try that. If it works then maybe you have lost the immobiliser chip in the key.
"Hasta la victoria siempre"
Posts: 5 |
I have tried both keys , the spare is brand new and unused!!
Posts: 490 |
I don't know if you are a member of the MSCC, if you are then in the December issue of Miscellany, Dave Wellings has a piece about keys and immobilisers, worth a read it could be related to your problem
Posts: 7,948 Likes: 218
Posts: 7,948 Likes: 218 |
Try charging the battery. One member on here found the immobiliser a little finicky about less than optimum battery volts. Thread here
Posts: 26,766 Likes: 427
Posts: 26,766 Likes: 427 |
Can you give us more details on what the car is please. Later cars have an immobiliser ring in the lock. If the battery is low it may not work well. As said search for the Dave Wellings thread on this
Posts: 2,055 Likes: 18
Posts: 2,055 Likes: 18 |
Here's Dave's thread on the subject http://www.talkmorgan.com/ubbthreads.php/topics/539514/1There is an issue with later Plus 4's. Try taking the key out of the ignition then rub the fob against the ignition barrel. This is usually sufficient to get the chip close enough to the induction loop to disable the immobiliser. Once the light goes out you have 30 seconds to insert the key and start the car.
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
Put the key in the ignition Paul. Don't turn it.
Put a battery conditioner on and the immobiliser will disarm in a few minutes.
PS - if my theory holds true, your Plus 4 will be 2016 onwards with an autophoretic coated chassis........
Posts: 5 |
Thank you all for your help, l have had the car on a trickle charge which said the battery was charged, but when I used an additional jump start the car started immediately and with all keys Beautiful day in Edinburgh, now can take the car out ,,but will not turn engine off till I return, Thank you all again
