7 members (DCH, teknome, High Hamster, Clipper, nick w, SteveT, Image), 385 guests, and 113 robots.
+8Rich 78
DaveW 52
Topics49,867
Posts837,611
Page 1 of 5 1 2 3 4 5
DaveW Offline OP
This turned out to be my last job of 2018. I'd been putting it off for all sorts of reasons, but yesterday came the right combination of available time, and warmish weather.
So, Panhard Rods are available now from a number of sources. This one is from SSL. Some rods secure to the leaf spring by a saddle clamp. This one uses a replacement lower plate for the U bolts.
And here it is. This is one of the early production versions.
This is the orientation on the car, which is just visible.
My first job was to remove the old U bolt plate. The nuts came off easily.
I did consider taking a leaf out, (both sides!) but in the end took the lazy option.
I locked the spring in place by inserting wooden blocks between spring and chassis while I did this. The centre hole on the plate wasn't big enough to fit over the leaf spring through bolt nut, but some drill and file action fixed that.
This is the old plate. Notice how its (cut) asymmetrical, chassis to the right.
Next I clamped the cross-member in place........taking care to get it straight!!!
When aligned I drilled the eight holes.....I bought some special drills for this, and they were very impressive.................
I cleaned up the surroundings and applied some galvanising primer to the holes. When dry I bolted the cross-member up and coated the threads with ACF50.
I fitted the rod to the crossmember.............
Later I would have liked to have tried it in the lower of the two holes, but the floor timber gets in the way and needs cutting slightly for clearance. By that time I'd had enough so maybe that's something for another time.
At this point I discovered that I should have put the bolt in at the other end from below..............
But I also discovered this clearance issue on full rebound.
Note that my Roadster has six leaves. More current cars with four leaves means an increase in the clearance here of the thickness of two leaves.
I also tested clearance on my Plus 4, but with the fuel tank protruding further forward by a significant amount, I'm not comfortable with the clearance I have, so for now I'm not doing this job on the Plus 4. Remember that every Morgan will vary slightly!!!!
So I had to drop the cross-member to get the bolt in (no way the nut will fit below) and I also cut away half the bolt head. Now its OK. It's feeler gauge clearance but it's clearance. I've fed this back to Peter B.
An alternative fix here would be to space the crossmember down a few mm, or file away a section of the cross-member.
I sprayed the whole thing with Tectyl 506 when completed.
This is clearance at static height.
Finally I checked for sideways movement between static height and full rebound using a straight edge, and there's no sideways movement. This took about five hours at a leisurely pace.
I'll report back after a test drive......
thumbs
Well done Dave. My car came with one so I don't have to fit one.
Another interesting article.
It would be very interesting to read how you feel the rod improves the handling.
I am considering a panhard rod myself as I feel the rear axle moving sideways and also can see the tyre rub marks on my exhaust.
4/4 2 seater 2001 model
Top man..well explained with good photographs
You should maybe write a book Dave.
xx
Panhard rod is a must on a trad , anyone on here who looks underneath and can't find one ..get one fitted asap as cornering/rounderbouts are dealt with much swifter !
DaveW Offline OP
xx
Such humour could only emanate from a Yorkshire bloodline.......... wine
Hi Dave,
I like the look of that and a great illustrated write up. Do you know the part number for this kit?
I couldn't see it on the SSL website?
Cheers
2009 4/4 Sport in Red
2022 Harley Davidson FXLRS Low Rider S
1977 Triumph Stag
Great explanation of the process Dave. Love the wheel supports too. Presumably you always use four of these together?
Rob T
2017 Tungsten Plus 4
You can't even give a complement these days without somebody having a go at you !!!!
Maybe time to move to a proper car forum like Ferrari and discuss the merits of owning a Morgan !!!
xx
DaveW Offline OP
Originally Posted By Redfate
Hi Dave,
Cheers
Give then a call Paul. It was advertised a couple of months ago in Miscellany but isn't in their current Ad.
