How can £1,000 for a rolling session be justified???
I have frequently taken motorcycles to rolling roads and it is normally around £50 for a power run and £150 for an hour to allow fuel/ignition mapping.
Rant over,
Thanks for the heads up Culminator
See I&J Macdonald for their r/road prices -£40 pounds I think and then£60 per hour of twiddling. Meabh.
There are different takes on this. I know it sounds a lot but there are valid reasons for both the prices to be correct.
At Surrey Rolling Road, you can go to a power run day and get chaged less than £50 for a run and a set of graphs power, torque and fuleing. For simple mapping again depending on what you are mapping Ignition ECU, Fuel ECU, Carbs or Disty then it's going to be different. Some even need a specific burned ECU as the OEM can not be re-programmed.
I would not see £1000 bieng off the mark if you need a burned chip, espeically for an initial engagement, second visits etc, tend to be cheaper.
An Aero at a top tuner is £600 and that can be done pretty easily. To get my sprint car done last year at Northampton Motorsport was about £600 and that covered setting up Twin 45's and mapping the 3d ignition (Omex 600) from scratch.
Austec have a great rep on the TVR Rover V8 front and I would say you are in good hands with them, you pays your money etc. etc.
