8 members (B3MOG, TBM, Doug J, Dek, MJF, Guern, Ian Wegg, Bunny), 223 guests, and 81 robots.
+8Rich 76
Topics49,861
Posts837,531
Jonny72
tom+4 Offline OP
morgan +4 2008
gr tom
Make sure the big white connector on the back of the instrument cluster is pushed home properly and that the pins are inserted and locked in place properly - that is what caused this on mine (can't remember colour of the wire - sorry)
Mark - No Longer driving
Does it blow a fuse when you set it to the second speed?
Nick
A two speed heater fan!!
What manner of modern sorcery is this?
wink
Bud
4/4 "Stanley"
SFG Offline
My heater knobs have no marking to indicate what position the switch is in. Hard to tell when at speed. Presume they're all like that, Sir
SFG
2012 4/4 Sport
I never use my heater fan
Craig Jezz
Why not?
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Why not?
With the temperature turned up, it always seems to be enough heat flowing through without the need for the fan.
Craig Jezz
As the heater fan switch is on the left of the dashboard, I have no choice as to whether it is used or not. It is firmly in SWMBO territory!!
Reg
tom+4 Offline OP
problem solved
dashboard dismanteld and
i took the two big white connectors of and back on
and it worked so tkx milligoon
