1 members (Bitsobrits), 304 guests, and 97 robots.
+8Rich 84
Topics49,860
Posts837,485
Jonny72
Page 5 of 5 1 2 3 4 5
Steve, Did you just split the bonnet, or did you cut out a center section to accommodate the width of the piano hinge?
Lance
1981 Plus 8
2016 Three Wheeler
2022 Corvette Stingray Convertible z51
Steve, do you have a fore and aft brace from nose piece to firewall? I really like the work you have done on that bonnet.
How did you separate the main bonnet section from the nose, what sort of tool did you use?
Online NoMood
Steve, do you have a fore and aft brace from nose piece to firewall? How did you separate the main bonnet section from the nose, what sort of tool did you use?
After separating the bonnet from the front cowl, I made two slow and careful cuts about .375" apart with a fine tooth jigsaw to accommodate the piano hinge, as you surmised. I cut perhaps .010 inside my marked cutting lines, then finished off the edges with a file, stroking away from the paintwork. By using a couple of layers of painters tape to protect the outer surface of the bonnet I avoided any exterior paintwork except for touching up the cut edges with a brush.
The hinge was pre-drilled for fasteners, which helps immensely in locating the holes. I added 10-32 thread nut-serts to the hinge, btw. I started with drilling the center hole on each side first, inserted the screw, then drilled the next one, inserted the screw, and so on. Because the bonnet has a slight curvature I think this is imperative to ensure you get the spacing correct.
Separating the bonnet and cowl is easy, just a few bolts. The trickiest part of the project was removing the partial bulkhead at the front of the bonnet that bolts to the cowl. This bulkhead was both edge and plug welded to the bonnet. Took me about 4 hours with a small pistol grip air grinder and 2" disc to grind away 'just enough' of the welds to allow separation without gouging the alloy bonnet itself. Fortunately I have become a very skilled grinder over the years, facilitated by being a poor to mediocre welder. The inner surface of the bonnet was wet sanded and prepped with self etching primer, which I decided to leave as is as I like the contrast, and it can always be painted later on.
There is no fore/aft brace to the front cowl, the mounting braces I made fasten to the front body mounts adequately locate the cowl. And nothing holds the bonnet on except the original 4 Dzus fasteners! That was not the original plan, but after hundreds of miles of testing, I've decided to leave it alone. The body lacing around the perimeter of the bonnet is essential to minimize vibration and and movement.
Late 2012 M3W
Steve: Congratulations on your accomplished craftsmanship. If the hinge is an aviation part, I believe it can be sourced from Aircraft Spruce. Would you mind sharing the part number?
Thank you,
Tom
M3W
RV-8 (built and sold)
Online NoMood
Tom,
The hinge is just a stainless item I found on Amazon: https://tinyurl.com/bonnet-hinge. Looks like they are now sold in 5 packs. I only had to buy one. In any case it needs to be thin, and not super precision due to the curvature of the bonnet. Needs cut to length which calls for some creativity in managing the ends.
Late 2012 M3W
Steve, if you had to do it again would you do anything differently?
What holds the other half in place while the opposite side is opened?
Online NoMood
Hmmm....good question. Still thinking about brackets to hold the front and rear of the hinge to the cowl/body. More for peace of mind rather than a necessity.
When one side is opened, the Dzus fasteners on the other side keep it in place. No problems at all. To remove the bonnet entirely just unfasten both sides and fold both sides up together and lift. Super light without the nose cowl.
The Dzus fasteners actually work as intended with this set up.
Late 2012 M3W
I was considering the split bonnet but I have the other spring loaded bonnet latches. Those things are not very rigid, like the drugs fittings.
With a fore to aft strut it could be setup to open the space a small amount to disengage tabs at either end of the hinge.
