Topics49,846
Posts837,383
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Is that blood on the carpet? paint spillage Bob Tomato sauce from a nice bacon & sausage sarnie
Posts: 411 Likes: 9
Posts: 411 Likes: 9 |
I'm sure you know that you should be very careful using a trolley jack on carpet! The trolley should be free to move so that as the point of lift moves backwards (as the arm swings up) the trolley tends to want to move forward to stay directly under the weight. If the car cannot move and the jack is snagged on the carpet it could be dangerous! Bottle jacks and scissor jacks just raise directly upwards, a trolley jack swings backwards on its arm as it is raised.
2009 4/4 Sport in Red 2022 Harley Davidson FXLRS Low Rider S 1977 Triumph Stag
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Doesn't  complain when you work on the car in the lounge?
Posts: 57 Likes: 1
Posts: 57 Likes: 1 |
Thanks for the useful replies and amusing banter. I've got to say carpet in the garage - i can tell your Morgan is spoilt....
Posts: 1,943 |
I'm sure you know that you should be very careful using a trolley jack on carpet! The trolley should be free to move so that as the point of lift moves backwards (as the arm swings up) the trolley tends to want to move forward to stay directly under the weight. If the car cannot move and the jack is snagged on the carpet it could be dangerous! Bottle jacks and scissor jacks just raise directly upwards, a trolley jack swings backwards on its arm as it is raised. This is important information - HEED IT!!!!!!
Button
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
I'm sure you know that you should be very careful using a trolley jack on carpet! The trolley should be free to move so that as the point of lift moves backwards (as the arm swings up) the trolley tends to want to move forward to stay directly under the weight. If the car cannot move and the jack is snagged on the carpet it could be dangerous! Bottle jacks and scissor jacks just raise directly upwards, a trolley jack swings backwards on its arm as it is raised. The trolley jack does move slightly when the car is being raised on the carpet, the arm swings as you say, and the block remains central (Block routered into the jacks lifting point) The handbrake is off so the car also moves slightly as it’s being raised. Once it’s fully raised then the chocks go behind the rear wheels inc axel stands in place.
Craig Jezz
Craig Jezz
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
One consideration when buying a hydraulic jack is the availability of service parts/service kits for them.
For example, I've just repaired my 20 year old Sealey Yankee trolley jack using an off the shelf repair kit.
My neighbour has a defective three year old jack from Halfords. No repair kit available and seals of such odd ball sizes, I can't find them anywhere!!
Arwyn
Posts: 220 Likes: 4
Posts: 220 Likes: 4 |
Some of these wood adaptors are impressive bits of kit. Personally, I have always used a large standard jack on my various Morgans over the years. No problem. It does have a built in rubber pad and operates well, with no slippage.
Craig, nice bit of woodcraft !
