8 members (DMC1904, John V6, nick w, JD44, Sloany, TomS, +8Rich, Grumpy2),
293
43
Topics48,364
Posts813,337
Members9,215
Posts: 308 |
They should have “zebra’d” the alloy chassis rather than the body. Geneva is at last something worth waiting for!
John 1936 Austin Seven Ulster Replica
Posts: 15,794 Likes: 14
Posts: 15,794 Likes: 14 |
Aero plus 8 with a couple of cylinders missing and a fan to make up for it, must make Peter J and the others happy their cars can only firm up in value They may firm up the value, but that is unimportant unless I want to sell. Do I? Don't know yet I will try one before making any decisions: I know what the engine is like as I have the same BMW B58 straight 6 in the M140, . It has a couple of advantages over Plus 8: peak torque from low revs and instant throttle response. Power: 250 kW (335 hp) at 5,500–6,500 rpm Torque: 450 N⋅m (332 lb⋅ft) at 1,380–5,200 rpm Assuming it has the same 8 speed gearbox as the M140 and the new chassis is as stiff as Aero platform, it could well be a better drive. The M140 weighs 1500kg, it is the sort of car that demands some driver skill: it has a lively back end and even with traction control it is easy to lose traction with a heavy right foot. I'm assuming the Mog will have better developed suspension than the 1 series but no traction control and will be lighter than the M140. So like the +8 it will be "interesting" The BIG question is the name! With a turbo Straight 6 I go for one of the following: Roadster Turbo Plus 6 Plus 6 is logical as it fits into +4 and +8 We shall see. Also, will there be a "modern (Aero like) body as well?
Posts: 5,587 |
Plus straight 6 ? Sounds slightly awkward ?
335bhp versus 378 bhp so down on power
Sound ? Er won't sound like a v8 .
But then there are no Beemer v8's that will fit.
Does the chassis need to be stiffer ?
Posts: 11,221 Likes: 159
Posts: 11,221 Likes: 159 |
That is funny, first came camouflage, then we saw dazzle camouflage, now anti-camouflage. As you say if it had not been dazzled up then it would have got clean away. Anyway good for Morgan, the more PR and coverage the better. Well I only hope that the slight delay in moving forwards does not mean that they are just finally testing the first diesel model....ahem  I would love to have a heard a video with sound rather than the picture so we could confirm it is the new engine/chassis development mule! Still happy with my bent-8 noise generator.
Another question might be around the rowdy exhaust option?
A V8 goes well with the boomtube dual side pipes and off beat noise. An IL6 with turbo's ? Exhalation is on one side so a single rear/side pair of exits ? Probably rear pair I guess. Also BMW have not been good at getting the volume out of their engines so Morgan can probably do well here.
Posts: 5,891 Likes: 22
Posts: 5,891 Likes: 22 |
do we know that it is a replace for the Plus 8? Could it not be the oft rumoured trad ie 4/4 , plus 4 with at last decent underpinnings. Exotic things like independant suspension and coil springs?
could be of real interest if it was.
We know that there is a new chassis.
We believe it will be fitted with a straight 6... Morgan say in the Autocar article it will have an engine "never before fitted in a Morgan". A straight six fits that statement. We understand it has fully modern independent suspension at both ends.
A previous statement from MMC said it is a bit wider than the trad chassis. From the front photo it looks to be as wide as a Plus 8, which has about 6 inches more cabin width.
I do not believe that MMC would have invested in a new alloy tub just for 1 car. I do not believe that that chassis is for a V8. BMW has a newer Turbo 4.4L V8, the N62, but it is getting a bit old, introduced first in 2008, but still very much in use. It produces up to 440 bhp. I do wonder if that engine will appear in the existing Aero tub, or more logically, in a second and modified version of the new tub in a couple or 3 years.
We also know that the BMW engines are semi modular, in as much as they all have a 500cc cylinder. So it seems to me that this new car is the start of a new series, 3 cylinder 1500cc, 4 cylinder 2.0L and the 6 cylinder 3L.
But I could be wrong....!
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
You can't call it a Plus 6 because that name should have been given to the V6 Roadster.
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
Speed Six unless Bentley have it wrapped up......
But my understanding was that the Roadster would carry on for a while as it is. Maybe until the engine stock runs out. The 4/4 is continuing for non-EU markets.....
So my logic suggests a 2.0 Plus 4. If it had around 200bhp it would be interesting.
Posts: 1,702 Likes: 105
Posts: 1,702 Likes: 105 |
Maybe army-specs!!!😜
Very strong marketing indeed!🙄
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
