1 members (New Zealand), 152 guests, and 14 robots.
+8Rich 103
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,511
AlexCreasey
Page 3 of 5 1 2 3 4 5
I'm likely to be refitting my seats this weekend (at long last). I want to replace the nuts bolts and washers whilst I'm there. The old ones are not in awful condition but I might as well, eh?
Question is: should I use BZP or Stainless A2 nuts and bolts? Why?
Neil
1988 Morgan 4/4 4 Seater, black
1996 LR Defender 110, white
2009 Honda Deauville, black
DaveW Offline OP
It doesn't really matter Neil. These fixings are not stressed, so stainless is fine. But if the originals are reasonable, try putting them in vinegar for 24 hours. Clean first with white spirit to remove oil/grease, and they will come up really well. An old restorers trick. wink
Ok, my seat transformation is done.
In the begin i have provisory adapt the seat that he could be back completely.
Now i have transformed the high of the seat that he moves without problem, in the same winter works,I have renovated the foam and the flex of the seat, he is now like new. The carpet is replaced (DIY handmade from a doormat) and fixed.
Dave thanks again for many ideas, more Adaptations are done or will follow.
Don't Worry, Be Happy
Morgan 4/4 1985 2,0 Zetec
BMW R1200 GS
Triumph TR140
A yes, still a question. All the screws are too long, for the technical inspection(security) the need to be cut?
BMW R1200 GS
Triumph TR140
DaveW Offline OP
It's OK to cut the ends off underneath, but might be harder to fix next time!!! (unless you use new long ones & cut again).
I don't think the screws under the must be cut to pass the inspection. If so, I would be in trouble with the original setup.
Harald
Harald
Yes the old one what to short, as Dave said i had to replace them.
I Think “wait and see”, in April a have to go
BMW R1200 GS
Triumph TR140
Hi All, we have a year 2000 plus 4 and the seat bolts are rather long and hit speed bumps why r they so long is it worth cutting down or putting shorter bolts in?
Will try the leather touch up looks and sounds great. joy
Triumph Herald 1969 13/60
Morris 1970
DaveW Offline OP
You can cut them off Rob but if you need to take the seats out you will probably need longer bolts to get the nuts started. An alternative is to fit some spacer washers under the bolt heads as long as the bolt head doesn't interfere with the seat runners.
Thankyou I'm guessing many folk have these bolts too long and the first to hit speed humps mine must be a good 2 inch over
Morris 1970
