5 members (Rog, mph, cerealsurfer, TalkMorgan, riri), 85 guests, and 52 robots.
+8Rich 75
Luddite 50
Hacked email account
by +8Rich - 08/09/26 01:47 PM
Guess the car
by Soleng - 07/09/26 06:44 PM
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Topics49,888
Posts837,889
Hi, working on my 1976 +8 I left the ignition on noticed that the fuel pump never cuts out, should it cut out after a certain pressure is reached? Also noted that the right bank carburettor is dripping fuel so I assume the float valve is not shutting off correctly. I'm also wondering if this is something to do with the smoking engine I get on occasions
Any thoughts gratefully received! Also, anyone know the model number of the Stromberg's fitted to this era car?
Long time since I worked on Rover V8's but sounds to me like the float or the needle shutoff valve might be the culprit. There could be a little bit of dirt preventing it from closing properly (even if you have fuel filters), the valve could just be worn or maybe there is a leak in the float itself. Generally I do not favour Strombergs and their troublesome diaphragms so you might want to consider swapping them for SU's at some point.
Thanks for your response and I cant have had enough coffee this morning they are of course SU's fitted!! Stromberg on a totally different car!!
Still wondering about the fuel pump - I would have thought it should stop when system is pressurised?
As griffo pointed out. If needle valve is leaking the fuel pump will not shut off. Fix needle valve!!!!!!!!!
Button
Ray Offline
I had a 79 +8 on su carbs the pump always kept up a slow tick. But a slow petrol drive will make it worse.
There is also a seat. Replace both the seat and needle valve. Or at least use carb cleaner and flush it.
Button
Also check fuel pressure. Should be no more thsan 4-5 PSI.
Button
Yes that's a very good point. Too much pressure and it will lift the valve off the seat. If it is too high you could always fit an in-line adjustable pressure regulator.
on my 70 +8 there is a return line to the fuel tank from the right
SU carb. The engine mounted fuel pump is long gone but I still recirculate to the tank. I think the reducer hole is about 1/16" so it only builds up pressure of 4-5 psi.
'34 Family 4
'70 +8
'03 Hummer H2
When I purchased my 77 +8 18years ago I would have the fuel pump ticking frantically and petrol overflowing out both SU carb overflows. Somewhat scary. I purchased 2 kits for the SU's that incorporated ( from memory ) a vitron tipped float needle and redoing the H1F6's fixed the problem. I have happen twice where one float needle has hung up and the motor starts and runs on 1 bank. Once it fixed itself when turned off and restarted the other time needed a light tap around float bowl.
Doug
from deep deep downunder.
