Topics49,904
Posts838,075
Posts: 1,246 Likes: 30
Posts: 1,246 Likes: 30 |
I am sure their must be an easy way of lubing the fwd spring mounting bushes. Any tips as my near side has developed an annoying squeak. thanks
Posts: 52 |
All the motion here should be flex in the rubber bushes. Squeaking could indicate a loose through bolt or a bad bush. Lube (oil or grease) is destructive to rubber and will greatly shorten the life of a bush. regards, Phil
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
I did this in the dry weather last summer. My silicone spray can had a thin plastic tube attached to the nozzle. I was able to insert it into a drinking straw and shoot it up through the gap in the heel board that the spring passes through.
Roger 2011 Plus 4
