6 members (B3MOG, Wouter, John Winn, JohnHarris, Graham, G4FUJ, RedThree), 181 guests, and 39 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,042
#560584 17/02/19 11:00 PM
IcePack Offline OP
I am sure their must be an easy way of lubing the fwd spring mounting bushes.
Any tips as my near side has developed an annoying squeak.
thanks
All the motion here should be flex in the rubber bushes. Squeaking could indicate a loose through bolt or a bad bush. Lube (oil or grease) is destructive to rubber and will greatly shorten the life of a bush.
regards,
Phil
Rog Offline
I did this in the dry weather last summer. My silicone spray can had a thin plastic tube attached to the nozzle. I was able to insert it into a drinking straw and shoot it up through the gap in the heel board that the spring passes through.
Roger
