3 members (JohnHarris, Socalm3w, TBM), 298 guests, and 44 robots.
+8Rich 94
John V6 50
Posts837,997
rockabilly john
BobJ Offline OP
I gave up waiting for MMC to have them in stock so went to S-V-C who had just taken delivery and assured me that their Lucas copies were good quality so I took the plunge. My original Wipac's had the sidelights fitted within the lamp bowl so this meant that S-V-C would need a drill the Lucas bowls and supply a side light fitting - a service that is offered on their website so I paid for them to do that as well.
Now hindsight is a wonderful thing and with that benefit I would have removed the original lights and had a poke around to find out what's what before ordering. However I didn't so when asked the question 'where do you want the side lights fitting' I went by the Tribar pictures on the MMC website and said at a midpoint between the headlamp bulb aperture and the edge of the reflector bowl doh
The lights eventually arrived and I was a little disappointed to find that one of them had some sort of film or mist on the inside of the lens. Arrangements were made to send it back. In the mean time I did what I should have done from the off and removed on of the original headlamps and dry fitted the remaining good Lucas.
You can see the difference in sidelight location straight away:
This caused a problem because the W5 bulb holder supplied by S-V-C fouled the plastic headlamp black plastic nests fitted in the wing recess and put an undue amount of strain on the plastic beam adjustment screws. Bugger!
This can be seen where the dust has been rubbed away at the 6 o'clock position (don't worry - it's all been cleaned up in there now smile. Then I realised that the original 4W headlamp bulb holder was a perfect fit within the grommet that S-V-C had put in the hole drilled in the Lucas - the problem being it sat outside of the Lucas rubber dust boot and was not covered by the original Wipac one as shown by the black marker pen line in the top photo.
So I took photo's and measurements and contacted S-V-C knowing the that faulty light unit had not yet been delivered back to them. The plan was that they would hopefully drill the replacement lamp as per the photo and I would have to stump up for one more unit. An expensive mistake but the bonus would be that I wouldn't have to mess around with the wiring and they would effectively be 'plug and play'.
Having phoned S-V-C and explained the problem they readily agreed to drill the replacement as per my photo and to my delight and surprise, agreed to send a second lamp similarly drilled free of charge. Fantastic service clap
So fitment day was yesterday. I ended up having to carefully trim down the red shroud around the wire (as below) to 2mm because it's original length caused the dust boot to sit proud of the reflector bowl but once done, the boot was a snug fit. There is also plenty of clearance between the sidelight build and H4 headlamp bulb which had been a nagging concern.
So job done and very pleased with the aesthetic results. I've read that these Tribars are not great in terms of light output but I was aware beforehand so went into it with my eyes open.
Before:
After:
2017 4/4 80th Anniversary
They certainly look the part on an 80th Anniversary car. Nice work , even if it took rather longer than you anticipated . I have also heard good things about SVC.
I have a set of tri-bars removed from an earlier +8 if anyone else wants to attempt this. Yours for the cost of postage
Andy G
1999 +8 , Indigo Blue.
You made a good choice. The ones the factory supply, if they are still the ones I got from them for Nero were dreadful. They looked great and nighttime performance was reasonable until I drove in the rain and then fog. The scatter was just too dangerous.
1936 Austin Seven Ulster Replica
That looks the mutt’s nuts. thumbs
Good job, and well done SVC for providing such excellent customer service.
Giles. Mogless in Paris.
Good job done they really do add a touch of class to the front end, well worth your wrestling.
Great service from SVC is good to hear.
good choice there Bob - they really suit the look of the car thumbs
Also, nothing quite like getting unexpected good service and a freebie to boot!
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
They look the business
Very tempted
I am with Richard: Good job done they really do add a touch of class to the front end...
I'm still thinking about what I'm gonna do.
If there were not the problems with the light. confused2
I like the looks, very nice job too!
Always like the practical hands on postings!
Thanks,
Bert
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
This is very classic and noble. You made an excellent job.
I chose the not-so-beautiful look of new LEDs because I ride a lot in spring and autumn at dusk and sometimes in the dark when we come back from a day tour.
