7 members (TeddyAds, Mogdavid, drew, Strathaven, JMcL, RichardV6, Bitsobrits), 317 guests, and 49 robots.
Topics49,846
Posts837,379
#563993 06/03/19 08:41 AM
I had to take noise test for my Roadster and failed pretty spectacularly. We took off the muffler and found it was a simple pipe - no baffles at all!
Check this video out and share any of your own stories and remedies please.
Morgan Muffler - I thought there was a hose pipe ban!
skype: jim.a.james
It is not a "simple pipe". It is a straight through absorbtion silencer -- the more efficient sort in terms of back pressure. You could add a baffled silencer but it would cut down on performance. Suggest you use a restrictive baffled silencer just for the noise test and then replace the straight through one afterwards.
Man man zo tungje. Liang tiao tui zo lu.
Peter beat me to it. There is a perforated open pipe down the middle which is wrapped or lagged with sound absorbing 'wool' probably glass fibre. This lagging tends to blow out over time, and becomes less absorbing allowing more noise out. There are a couple of ways of dealing with this, the easiest is to take the silencer to a small exhaust company and ask them to cut the end off and re-pack it, or just get another one made, perhaps slightly longer if there is room, but for goodness sake don't start getting baffles put in or your performance will suffer. Or, you could buy a ready made silencer from someone like 'Car Builder Solutions', just google them if you don't know who they are.
