0 members (),
156
40
Topics49,911
Posts838,152
Posts: 2,096 Likes: 260
The TM in Talk Morgan Talk Morgan Expert
Pre-Production Morgan ThreeWheeler
For those who are having problems viewing Charles Morgan's photos, with his permission, here they are for your viewing pleasure. More information can be found on the Morgan 3Wheeler micro site
Posts: 870 |
Looks like a belt drive from the gearbox to the rear hub! Guess that ties in with the engine which is H-D? The engine is apparently an S&S from S&S Cycles. And, yes, it's belt drive (sounds like I know something, but the proof is in the pictures, plus I was told so in an email from Morgan Motors). [edit: The gearbox is from Mazda, just in case you didn't know] Will start a listing for my one then...and it is RHD! Guess it will be a lot cheaper too! Yes, your's will probably be cheaper, but the Morgan will be all new and have seatbelts (lol). With regards to RHD/LHD, MMC will make both, so you get to choose which one (depending on the laws in the country of registration, of course). So if you need a RHD, that is what you will be getting. If you need the other, you'll get one of those.
Posts: 28,912 Likes: 354
Posts: 28,912 Likes: 354 |
Belt drive hub in the piccy.
I thought the original blurb said it was going to be shaft drive, single sided swingarm (anyone remember from the factory tour a few months back?)...
Cheers,
Posts: 3,727 |
Belt drive hub in the piccy.I thought the original blurb said it was going to be shaft drive, single sided swingarm (anyone remember from the factory tour a few months back?)...Cheers, You are correct Sir. The question was how would the shaft fit with the wheel centered (or something like that) Interesting Pics though. It will be a nice car I am sure.
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
Looks like a well marinised dash panel! oh that's what it is! at first glance I thought it was a ghetto blaster, should have put my specs on
So, Who tried to add a photo to those already here? Not to worry, we know what the thread is. Further photos have appeared on yfrog, which give a really good indication of how the rear end is put together. Sure enough, no single sided swingarm. Shaft drive from the gearbox to the 90 degree gearbox you see here, with belt drive from that to the wheel. Adjusters for the rear axle to tension the belt (just like a m/cycle) can be seen and it all fits between 2 approx 4.5 gallon fuel tanks - hopefully with enough travel to drop the swingarm sufficiently to remove the axle when the rear wheel needs to come out. Rear tyre is a Toyo car type. Anything else? Probably lots, but I'd really like to see this thing in the metal now.  Wound the other half up by saying I'd bought another Mog (then let her see the Vitesse 1/43rd scale +8 on the dining room table  ). No doubt I'm still in trouble though  Cheers,
