7 members (BHV, Paul F, +8Rich, TBM, hillclimber, Aeromax51, piquet),
251
45
Posts837,953
Posts: 513 Likes: 2
Posts: 513 Likes: 2 |
So I replaced the radiator on my duratec plus 4 with an aluminium one - it's a long story but I bought it off another owner secondhand.
However, I'm getting a leak from the big top hose. I have tightened it as far as I dare. I wonder if I have gone too far.... is that possible (I used a small socket set just to get in there).
Any tips for getting it to seal before I take it off and have a good look? It's all very annoying as I tightened it up a bit after noticing the leak and I have definitely made it worse. And I am about to go on holiday so will be thinking about this all holiday!!!
Thanks Nick
Posts: 663 Likes: 14
Posts: 663 Likes: 14 |
I had the same trouble with the alloy radiator on Possum after I installed Evans Waterless Coolant, which seems to find every little orifice. Cured it with Radweld. I would not overtighten the clamp. Are you sure the hose itself is not porous?
Posts: 513 Likes: 2
Thanks. Well the hose was fine on the previous radiator. I'm wondering if a turn or two of amalgamating tape before fitting the hose might help.
Posts: 305 |
Try using 2 jubilee clips .It worked for me .
Jimmy 2015 4/4 Sport Green 2018 VW Tiguan 1969 Morris Minor Traveller 1960 Morris Minor Saloon
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Old tired rubber.
Replace it if you can for piece of mind.
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
There have been a lot of threads on this "problem" and many have had slight leaks when changing from original rads to new aluminium rads.
I had the same on my Zetec and to this day I get a very slight weeping especially on very cold days when the aluminium seems to contract a bit.
Although mine was annoying, it seems to have settled down now and the water loss is negligible.
I changed to silicone hoses at the same time.
Bob
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
Try using 2 jubilee clips .It worked for me . with the clamps at 180° to each other.
Posts: 3,481 Likes: 42
Posts: 3,481 Likes: 42 |
Just like the Kerry man who used 2 condoms — “to be sure, to be sure!!”
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
Try using 2 jubilee clips .It worked for me . with the clamps at 180° to each other. Richard knows his stuff  this helps to equalise the distortion of the rubber as the clamp is tightened
Posts: 513 Likes: 2
Ok folks, many thanks. I'll try this first
