Topics49,848
Posts837,408
Posts: 557 |
My 3wheeler has been parked for a week and my garage constantly smells like gas.
I’ve put some UV dye into my gas tank and inspected all fuel lines around the fuel filter/pump/canister as well as fuel injectors - I cannot see a leak.
Do you guys have any ideas how to detect it?
Posts: 132 Likes: 1
Posts: 132 Likes: 1 |
Hi kankeL
I've had those symptoms which turned out to be a crack running through the weld on the tank front bracket. The lower front of the tank was damp but could only be seen from underneath A new tank is being fitted on Tuesday under warranty.
PaulR
Posts: 557 |
Hi PaulR, thanks a lot for the tip! I have the same crack :-( passenger side tank. Hope Morgan can address it in a timely manner :-)
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Wow, that's taken some time, I thought it was going ot be done a while back. Hope to see you fully back on the road soon
Red Leader
Posts: 132 Likes: 1
Chris I've never been off the road completely..I glued a patch over it...shouldn't really say that!
PaulR
Posts: 557 |
Chris I've never been off the road completely..I glued a patch over it...shouldn't really say that! PaulR, what did you use to patch it? Did you do it from underneath the car?
Red Leader
Posts: 132 Likes: 1
kankeL I used a patch of 16G alloy and araldite 2 part epoxy with plenty of overlap. Because it was the tank with the fuel pump once that was removed I could see the crack on the inside through the pump hole so glued it internally, but don't see why it wouldn't work externally.
PaulR
Posts: 557 |
Thanks!
Did you remove the tank from the car, or just the pump?
How hard is to remove the tank? I will contact Morgan here for a warranty claim, but I expect it will take a LONG time, so trying to see what my options are.
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
I had a weld failure in my +8 - right in the middle of the weld and impossible to see.... but it let out a very fine mist of fuel. Had to replace the whole tank.
+8 4.8
