10 members (MartO, RedThree, +8Rich, High Hamster, jbk, RubyMog95, JohnHarris, James B W, RichardV6, Peter G3VNH), 303 guests, and 100 robots.
+8Rich 76
Topics49,869
Posts837,664
Moggo
Page 5 of 7 1 2 3 4 5 6 7
Originally Posted By minikeefy
As mentioned previously mine is Zircotec coated and has not caused a problem for me (It doesn't seem to be as close to the water feed as yours though..
Perhaps
This from Autospecialists would be a 'prettier' solution.. Stainless Steel Exhaust heat shield
Keith,
Where did you source those braided pipes, and that beautiful overflow tank - was that a standard fitment on your car?
Roger.
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
A very well dressed engine indeed.
Apologies of late response...
The header tank is the standard one with this neat AutoSpecialist header tank cover (simply sticks on top with double sided pads).
Header Tank Cover
Also they do a nice cap cover as well..
Header Cap
I tweaked the position of the tank slightly to get it tucked under the heater box overhang and I was pleased with the result as well.
I used Stainless Braided fuel line available from CBS Online
Stainless Fuel Line
and remember the address is...
Father Christmas
Lapland......
drive
Keith
Thanks for the info Keith.
+1.
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
Keith, you are becoming King of Bling........ somestick
So speaks the Queen of Neoprene...
Keith. By the way, what do you use to provide a good end-detail on the pipes?
Roger.
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
Originally Posted By nputtick
I'm considering replacing the standard rad in my (low mileage) 2005 4/4 focus zetec (i.e. 1.8 blacktop engine). On recent hot days, driving at "comfort" speeds - not thrashing - over the moors, the fan has been running almost constantly when the engine is under load, usually stopping only when running downhill off the throttle, or idling. Temp gauge is showing 100-105 deg. I'm pretty sure the fan is operating normally as when starting from cold and leaving the engine to idle, it comes on after a few minutes and cycles normally - it is when driving that the constant fan running becomes evident.
With this "performance" I would be loathe to take the car somewhere really hot or to the Alps etc. The only modification to the car is a Librands 4-2-1 s/s manifold and sports exhaust system which did increase power (about +15 bhp on dyno), everything else is standard. There are no badges or other obstructions to the grille. The car has been regularly serviced and the cooling system checked, no leaks, two hoses recently replaced (preventatively - chafing) etc.
The Mulfab radiators are described as about 15% greater surface area, which doesn't sound an awful lot. There is a heavy duty racing version, presumably bigger again? Having the correct mounting points and hose positions would be important.
http://www.mulfab.co.uk/our-products/20/aluminium-radiators-cooling-systems/aluminium-44-radiators
Does anyone have any experience of these radiators, or any alternative suggestions? I will contact Peter at Mulfab for his advice too.
Thanks Nigel
Hello Nigel,
I realise this is from some time ago but I wondered if you resolved the hot running issue?
So far I have:
Changed the thermostat
Changed the radiator for a mulfab one
Made and fitted an undertray to reduce back pressure in the engine bay.
Made and fitted an intake cowl to duct air in below the bumper
Moved the number plate so that it's level with the bumper
Removed the stainless steel mesh behind the grill
Made and fitted side cheeks to block off the area between the rad and the cowel
AND - still the fan comes on, even in this weather so I would be very interested to know if you had any success?
Thanks and regards
Simon
Simon
2002 4/4
2021 Audi A1 sport
Simon,
At what temperature does your fan switch on?
I can't remember, which engine do you have?
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
