0 members (), 311 guests, and 95 robots.
+8Rich 84
Topics49,860
Posts837,485
Jonny72
In November I purchased a 1973 Plus 8 that had, in period, a set of 6" wire wheels (as on 289 AC Cobra) installed. There is some thought that to accomplish this the Plus 4 wheel assemblies may have been used. Apparently the early Plus 8 rotors were thicker than Plus 4 rotors. Can anyone confirm this, and if so, can anyone tell me the actual thicknesses of either or both? Thanks in advance for any info.
Tom Morris
1972 Plus 8
1932 Super Sport "Beetleback"
1961 Morris Minor Tourer
1972 Triumph T120V
Tom
Most of the data you need is in the article above as recommended by JohnV6.
Many +4s (especially the racers) upgrade the brakes by fitting the +8 calipers (which entails changing the caliper mounting bracket I seem to remember) which is an improvement. Also experiment with brake pads. The +4 brakes are good and using a fade resistant pad will to some extent compensate for the extra weight of the +8.
If you want to revert to standard +8 parts it could be an expensive journey, using the items from the later wire-wheeled cars. Your system can be made to work well as long as you are not expecting race performance.
Andy G
1999 +8 , Indigo Blue.
Ray Offline
The early 69 +8 I had was fitted with escort Mexico/Capri calipers and rotors. Never had a problem with them ,even in hard use.
Interesting Ray,
how did you you manage to modify the Ford rotors to fit?
Ray Offline
Originally Posted By Horror
Interesting Ray,
. They were on the car from new.
