0 members (),
313
32
Topics49,897
Posts838,017
Posts: 175 |
Took the car out for a good run around and shakedown following a long winter lay off. The Chrome rim on one headlight came adrift when i went over a big bump. Stayed attached to the car by the screw at the bottom. I put it back on but at the next bump it came adrift again!!! Has anyone got a way of putting a screw in the top to stop it coming off? Do these wear over time or could the fault be with the plastic lamp surround to which it attaches?
Andy 2014 Morgan Plus 4 VW T6.1 campervan
Posts: 8,696 Likes: 416
Posts: 8,696 Likes: 416 |
The headlamp rim locates on two broad lips roughly 10 and 2 o'clock on the plastic surround. It's then held in place by a single self tapping screw located around 5 o'clock into a hole in a raised plastic block. Significant downward force may be required to locate.
It's therefore possible to miss locate it. Not saying that happened just a possibility. MMC currently also place a short length of self adhesive neoprene strip across the top of headlamp securing ring to tighten fitting of rim and/or prevent rattles. Was this present?
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
We found the neopreme also stops the dreaded whistle at speed as air rushes through the rim!
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Posts: 175 |
No neoprene on the ring. I will have to get some and see if it helps keep it on.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
The fit is poor, but by spacing the rim away from the light unit at the screw using a neoprene spacer, it better locates the rim at the top.
Plus neoprene all the way round reduces or stops the whistle.
Posts: 655 Likes: 12
Posts: 655 Likes: 12 |
We found the neopreme also stops the dreaded whistle at speed as air rushes through the rim! Isn't the whistle part of original Morgan safety system: the built-in wildlife deterent?
Harald +4 4-seater 2008 Squadron Blue
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
It attracts insects
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
It attracts insects Surely the average blue bottle has enough speed to dodge a trad.
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
1972 4/4 2 Seater
It takes lightning reactions from the driver to bag the biggest bluebottles Howard.
