3 members (Jensen1960, Alistair, Image), 352 guests, and 58 robots.
+8Rich 81
Topics49,859
Posts837,501
Jonny72
Page 2 of 5 1 2 3 4 5
I got some rollers to have in stock just in case!
And certainly you need good drills to get through the chassis easily, I found that when I fitted my Panhard rod!!
MDS61 Offline OP
Thanks all for the info so far...all good stuff, appreciated cheers
However can someone take an image of where - the BRB attaches to the chassis.
Also are the BRB at 90% to the wheel?
Sorry if these seem dumb questions but if yer don't know, yer don't know! innocent
Mark
2004 Roadster S1 3.0 V6 gone!
Mark
Before I refubished the brakes and fitted new hoses
but
you get the idea
holes were already on the chassis, no drilling required
Magwa
1950 Allis Chalmers B tractor
2000 Porsche boxster
2014 Skoda yeti 4x4 elegans
These might show it more clearly
Craig Jezz
MDS61 Offline OP
Thanks Craig, that now makes perfect sense!!
Appreciated - regards Mark
Mark
As someone partly touched on, be very careful re-threading top bolt back in. Double, double check you have picked up the the right thread when re-introducing the bolt before tightening up.
but
you get the idea
Steve, I see you use Yorkshire axle stands laugh2
Jon M: It's what is left after parking in a Liverpool car park!!
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Yes , Liverpool is not that far away!
To be fair I can't feel any difference in the cars braking either with or without BRB's!!!!
Magwa
MDS61 Offline OP
Finally got around to fitting the Reaction Bars. Very straight forward, the chassis - was easy to drill as I had new cobolt drills - the only difficult moment was the top bolt was tightened to 2 million pounds ft torque!!
I had to get the long breaker bar on it.
Onto the exhaust now, just removed the silencers, taking them to a specialist exhaust manufacturer to get a pair made up...the ones I will spec - WILL weight lighter then the ones i took off, they are sooo heavy!
Thanks for your help gents.
Mark
Mark
