7 members (Alistair, sewin, MATTMOG, High Hamster, Ian Wegg, Morganmike, IcePack),
343
62
Topics49,859
Posts837,515
Posts: 22,360 Likes: 353
Posts: 22,360 Likes: 353 |
I got some rollers to have in stock just in case!
And certainly you need good drills to get through the chassis easily, I found that when I fitted my Panhard rod!!
Posts: 979 Likes: 2
Posts: 979 Likes: 2 |
Thanks all for the info so far...all good stuff, appreciated  However can someone take an image of where - the BRB attaches to the chassis. Also are the BRB at 90% to the wheel? Sorry if these seem dumb questions but if yer don't know, yer don't know!  Mark
2004 Roadster S1 3.0 V6 gone!
Mark
Posts: 970 Likes: 1
Posts: 970 Likes: 1 |
 Before I refubished the brakes and fitted new hoses but you get the idea holes were already on the chassis, no drilling required
Magwa 1950 Allis Chalmers B tractor 2000 Porsche boxster 2014 Skoda yeti 4x4 elegans
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Craig Jezz
Posts: 979 Likes: 2
Thanks Craig, that now makes perfect sense!!
Appreciated - regards Mark
Mark
Posts: 220 Likes: 4
Posts: 220 Likes: 4 |
As someone partly touched on, be very careful re-threading top bolt back in. Double, double check you have picked up the the right thread when re-introducing the bolt before tightening up.
Posts: 8,675 Likes: 491
Posts: 8,675 Likes: 491 |
 Before I refubished the brakes and fitted new hoses but you get the idea holes were already on the chassis, no drilling required Steve, I see you use Yorkshire axle stands
Posts: 2,222 Likes: 182
Posts: 2,222 Likes: 182 |
Jon M: It's what is left after parking in a Liverpool car park!!
Posts: 970 Likes: 1
Yes , Liverpool is not that far away! To be fair I can't feel any difference in the cars braking either with or without BRB's!!!!
Posts: 979 Likes: 2
Finally got around to fitting the Reaction Bars. Very straight forward, the chassis - was easy to drill as I had new cobolt drills - the only difficult moment was the top bolt was tightened to 2 million pounds ft torque!!
I had to get the long breaker bar on it.
Onto the exhaust now, just removed the silencers, taking them to a specialist exhaust manufacturer to get a pair made up...the ones I will spec - WILL weight lighter then the ones i took off, they are sooo heavy!
Thanks for your help gents.
Mark
Mark
