0 members (), 238 guests, and 29 robots.
+8Rich 89
Topics49,841
Posts837,323
Christoph
Page 3 of 4 1 2 3 4
#570639 05/04/19 03:48 PM
5 Images
My new Morgan+8
At the end, after all these years, I got my +8
Cheers,
Roland
33 Comments
Super looking Mog
Love the MK dash and wheel
Ditto. Enjoy the car.
3.7 Roadster
Porsche 964 C2
JCW Mini Cooper S Cab
BMW F750GS
+4 4 1995-2002 / LM 62 +8 2002-07
Originally Posted By Roland +8
Good morning,
the +8 is build in 97. So it's a "long door" model if I'm right.
1997 was the changeover year, so it could be either. The indicator repeaters on the scuttle panel suggest to me that it is a short door car. The other method to differentiate is the dashboard , but with the MK version being different that is not possible. However with MMC you never know, and it might be a "hybrid" of the two.
But nevertheless it is a lovely car. Congratulations.
Andy G
1999 +8 , Indigo Blue.
I think it's a short door from the shape around the front edge of the rear wing. But it could easily be a hybrid. Is the bulkhead stainless steel?
DaveW #571011 08/04/19 09:16 AM
Did not the short door models have windscreen demister vents?
Brian
Jersey and Spain
Rovert #571013 08/04/19 09:18 AM
Yes Brian.
When the long door came in there wasn't room for them, so electric windscreens from then on.
Actually on My +8 Bitsa I used a long door chassis but installed a short door body tub. I know it is a long door chassis because the crossmember in back of the seat has been flipped, lowering the spring perch. As well the later seats are modified on the outboard edge to clear the spring perch allowing the seat to slide back farther giving more leg room. I did not realize this until I installed the later Roadster Type seats.
Button
Button #571166 09/04/19 09:08 AM
Very interesting. It doesn't have demister vents but the windscreen is heated...
And I will have a look to the bulkhead
If you can post a side on view of the bulkhead, door and rear wing we should be able to identify which body.
Having looked closer, the wings look like Superform, so I'm leaning towards early long door.
DaveW #571282 09/04/19 06:39 PM
There are 3 new pictures and I hope it helps to find out if it is a long /short door.
ANd even the question if the wings are superformed would be very interesting for me.
Thank you
All the best, kwa heri
Roland
Morgan Plus Four MY23
Long door and superform I would say, more importantly though a beautiful car thumbs
I have had a 1994 short door and my present 1999 long door and unless they are together it's not easy to tell. If you run your fingers along the inside lip of the wing you can normally tell whether it has the steel former inside it to identify the wing type.
The indicator on the scuttle has me puzzled for a long door superform though but hey it's a Morgan wink.
Page 3 of 4 1 2 3 4
