Posts837,932
Posts: 1,338 |
Hello guys. I need a new set of spark plugs. I have been using the champions but I don’t like how i have to regap them often. Any suggestions?
Posts: 902 |
Posts: 365 |
By the way on the ecu has an auto tune feature but unless you can merge the map the auto tune can only correct to a certain level. Mine had topped out. If you load the protune software you may be able to see if you ran out of headroom. Just don’t recall if you can see it on a locked ecu as my ecu is unlocked
2017 M3W Sport Green
Posts: 1,338 |
The link is to the exact part number correct? Part No. DCPR7E Stock No. 3932
Many Thanks
I just ordered them from ebay, a US seller 4 for $12
Thanks again
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
The NGK DCPR7EIX Stock 6046 Iridium ones are better. This info is on the Alternative Part List on this forum.
Posts: 1,338 |
I also ordered these as i like how (NOTE: NGK Solid Tip Spark Plug. Tip is non-removable.)
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
 24 Sparks for 36€
What engine have you got atalante83, a Rolls Royce Merlin?????
Posts: 1,671 |
I dont like missing parts
