Topics49,917
Posts838,224
Posts: 3,643 |
No problems on my 8year old / 30000 miles. Brake fluid is changed every 2 years.
Posts: 2,782 Likes: 5
Posts: 2,782 Likes: 5 |
No worries about seizing wheel cylinders.. Don't have any! Mind you cable brakes don't do much to stop the car either.. Had silicone fluid in my AH which avoids any corrosion issues.
Steve 2008 4/4 1.8 Duratec
Posts: 939 Likes: 46
Posts: 939 Likes: 46 |
As I had to replace the cylinders on mine, I assume the fluid was there for the last 10 years or more. Did not have a proper look on this as the car chose me...
Now it is properly serviced...
1973 2CV AK400 Ralley 1985 plus 4 four seater 1992 Peraves ecomobil bicycles (pedersen to recumbent)
Posts: 1,116 Likes: 17
Posts: 1,116 Likes: 17 |
Hi, What is the best source of rear brake cylinders? Can you use Transit ones as previously noted on here? Noticed my pedal sticking a bit, greased the pedal box so is now a bit better.. Thanks Will
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
It's said that the cylinders are Transit, however if you search Transit rear cylinders, the list in endless for all the various Transit configurations.
Posts: 8,708 Likes: 501
Posts: 8,708 Likes: 501 |
I always thought it was Transit shoes / linings & the Cyls were Mog specific
Many, many years ago during a spell in the parts trade we used to dread someone needing Transit hydraulics parts as the parts books ran to dozens of pages as Ford would swop from Girling, Lockheed & even a German type at random
