4 members (CooperMan, piquet, IcePack, mph), 283 guests, and 41 robots.
+8Rich 91
Topics49,841
Posts837,312
Page 5 of 5 1 2 3 4 5
ASR3 #705977 06/06/21 12:58 PM
That is interesting. Wonder why the thing melted?
Also good to know the source of the fuse block.
ASR3 #705987 06/06/21 02:31 PM
The brand is MTA provided by TME .EU.
https://www.carbuilder.com/uk/20-way-mini-fuse-module
Originally Posted by barking orifice
My 2016 3-wheeler won't turn ov er. I hear thefuel pump, turn signals but no click from thesolenoid.,
Does the 2016 model have an immobilizer?? Where is it located, please. Thanks for any help.
Your 2016 M3W can have an immobiliser fitted if it was specified, it was an option. If it is fitted there will be a flashing LED in the middle of the instrument panel at the top and you should have a fob attached to the key that you put near the ignition lock to deactivate the immobiliser. I assume you are pressing the starter button and not just turning the ignition key? I am not being funny about it but I have heard of people forgetting to press the starter button when they haven't used the car for some time.
ASR3 #706045 06/06/21 10:59 PM
Adam, regardless of whether or not your battery is duff your engine has almost certainly wet sumped to some extent which will make it more difficult to start or possibly blow a crank oil seal. Get yourself one of those indented plastic oil change cans, that will just slip underneath, drain the oil then put it back in the tank. Then start the car with the oil cap off with a fully charged battery or jump leads etc. 🤞
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
