7 members (+8Rich, Grumpy2, Image, Tresco, RichardV6, TBM, Rex_tulips),
281
38
Topics48,362
Posts813,327
Members9,215
Posts: 11,610 Likes: 43
Posts: 11,610 Likes: 43 |
I found mine under the crismas tree some years ago...
So selling it is no option - but making the best out of it. Coffee is very nice if the water is hot enough..,.
Beginning to regret selling it as I didn’t try it using water straight off the boil
Posts: 1,326 Likes: 11
Posts: 1,326 Likes: 11 |
An Aeropress woul dlikely do the same job for a fraction of the price
Formerly Aero S5 #80 Currently 911 (992) Targa in python green
Posts: 890 Likes: 29
Posts: 890 Likes: 29 |
Would be nice... The handpresso does a 120 psi and a very nice crema...
Don`t think the aeropress comes near. If it does - the price would be a sensation - and yes the handpresso comes for a hipster price>;-)
1985 plus 4 four seater 1992 Peraves ecomobil bicycles (pedersen to recumbent)
Definitely - you should have done it...
Miklos
Posts: 11,868 Likes: 138
Posts: 11,868 Likes: 138 |
Beginning to regret selling it as I didn’t try it using water straight off the boil I've got a Handpresso and I agree that the vacuum flask that comes with it doesn't keep the water hot enough, but I have found that a better quality flask (I use a Thermos Ultimate) does the job reasonably well.
Posts: 14,723 Likes: 149
Posts: 14,723 Likes: 149 |
I noticed that Aeropress also have a cold drip attachment. https://www.aeropress.co.uk/collections/shop/products/puckpuckThis caught my attention because years ago in Tokyo I sampled a cold drip coffee that was being offered in a Mitsukoshi department store to promote the coffee brand. It was an artistic, but Heath Robinson type affair, made using laboratory glassware, tubes, filters and such. I have often thought of building something to emulate it. At the end the coffee was further chilled by being dripped into a flask with an external ice pocket. The sample I was given in a small paper cup had a dash of chilled cream added. It was absolutely delicious.
Posts: 11,221 Likes: 159
Posts: 11,221 Likes: 159 |
Steam punk coffee machine Peter ? I look forward to seeing what you build!
 Yes, Aeropress will provide 1-3 bar, where espresso needs about 9 Putting a superfine metal filter on the aeropress does increase the pressure ... and the £180 saving will buy you several kgs of nice coffee beans - which will make as much difference as all that extra pressure And... I use filtered water from a Berkey filter which also helps with the flavour. I'm not quite fussy enough to brew coffee with a dedicated water filter specifically designed for coffee, but who knows, I may get there one day  Will writing from hipster central: Brighton & Hove
A page about "crema" from one of my favourite coffee suppliers: https://specialcoffee.it/en/italian-espresso-coffee/
Posts: 3,854 Likes: 2
Posts: 3,854 Likes: 2 |
Make it easy, get a Moka pot. All you will need is the backpack stove and a cup.
