Topics49,883
Posts837,819
Posts: 35 |
Im intending to do an oil change at the weekend. Any recommendations for brand and spec?
Thanks, Paul
EX Roadster Sport Ivory
Posts: 13 |
Ive always used Halfords 5/50 Competition oil in my Impreza turbo and my 4/4 with no problems
Posts: 22,367 Likes: 354
Posts: 22,367 Likes: 354 |
http://www.talkmorgan.com/ubbthreads.php?ubb=showflat&Main=3005&Number=30224#Post30224I use Mobil 1 5-30 but see the thread above. You could also ask your local Jag dealer since the engine appears in the X Type and S type in different guises. The Jag oil filter is XR8E6714AB I'm told, and I might give one a try next service. Make sure they haven't changed the filter spec on the latest Roadster.
Posts: 3,439 Likes: 7
Goodwood Drifter Talk Morgan Addict
Posts: 3,439 Likes: 7 |
I took a look under the hood of the RoadsterSports and the engine is completely different to my ex-2009mkII roadster!!!!
edited
Steven sold: M3W, Aeromax,V6, 4/4 4seater now: +fourLM62
Posts: 35 |
Thanks Guy's I did the oil change this afternoon and after a bit of research ( and helpful coments here) went for Mobil 1 5w-30 ( which is 20% off at Halfrauds). Its unhelpful that the cars handbook doesnt specify anything more than 5w-30 - not giving the Ford prefered standard or anything more) having always used Mobil 1 in my cars i'm happy with my choice.
I got the filter from my dealer and replaced the factory fitted Ford EFL600 filter with a Fram PH5803. It fits perfectly.
Just one challenge during the whole process - getting the old filter off. I have yet to ever get a filter removal wrench to work and yet again had to resort to the 'screw driver knocked through' method. At least the sump plug was easy to remove.
Posts: 413 |
Hello Dave, Is it necessary to change the oil on the rear axle and the gearbox so often? If I see the quality of oil, 15.000km or 3 year, are ok?
Don't Worry, Be Happy Morgan 4/4 1985 2,0 Zetec BMW R1200 GS Triumph TR140
I wouldn't leave it for 3 years, but that's just my preference. On low mileage I will be doing it every two, but annually for engine oil ...... so far anyay.
