0 members (),
271
42
Topics49,844
Posts837,360
Posts: 36 |
After breaking my frame, I have decided to generaly repair it. Original tubes, thicknes only 1mm I have increased from inside by inner tubes. New part is conecting lower and upper holdimg tube of frame. I think so is stiffness of frame much better and breaking is not more a problem... Here some photos https://drive.google.com/folderview?id=12dczBmvU687zfKJ-zZ2sIWlSUecbXZFuAndrej
Posts: 557 |
Nicely done! Would you please share more pictures of your oil cooler installation?
Posts: 1,562 |
Very nice fix Andrej - do you have any photos before the fix to show where the break was ?
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
After breaking my frame, I have decided to generaly repair it. Original tubes, thicknes only 1mm I have increased from inside by inner tubes. New part is conecting lower and upper holdimg tube of frame. I think so is stiffness of frame much better and breaking is not more a problem... Here some photos https://drive.google.com/folderview?id=12dczBmvU687zfKJ-zZ2sIWlSUecbXZFuAndrej Excellent work. Looks like a nice "row of dimes" on the weld. Shame you had to do it in the first place.
After breaking my frame, I have decided to generaly repair it. Original tubes, thicknes only 1mm I have increased from inside by inner tubes. New part is conecting lower and upper holdimg tube of frame. I think so is stiffness of frame much better and breaking is not more a problem... Here some photos https://drive.google.com/folderview?id=12dczBmvU687zfKJ-zZ2sIWlSUecbXZFuAndrej more photos (before & after) and detail would be good...
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
Looks like a well engineered solution.
Martin (Deano)
Posts: 36 |
Thank you all I have added the broken frame place photo. It is the same as I have seen here more times. I will prepare some photos from oil cooler, it is easy solutions you will see. Andrej
Posts: 1,671 |
Thanks for sharing- good looking repair Andrej
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Nice photos Andrej.
That oil cooler, what is it from and how did you introduce it to the engine, in what path? It looks nice and very nicely mounted.
