7 members (Image, Alan Patterson, Dek, MJF, stefan s, Nick55, Cat302),
257
101
Topics49,871
Posts837,679
Posts: 3,700 Likes: 131
Posts: 3,700 Likes: 131 |
When the heater fan switch on mine broke the closest I could find to replace it was from Holdens, code 020.034 Heater Fan 2-Speed Rocker Switch The only differences between it and my original were the icon and the fact the new one was illuminated. Curiously, although none of my existing switches lights up, I found the loom had an unused spade connector which I plugged in and it worked! So now when the Morgan headlights are on the heater switch alone glows on the dashboard. I expect one day I will replace the other three switches with newer illuminated ones. ~iw
Posts: 6,958 Likes: 117
Posts: 6,958 Likes: 117 |
We always knew you were illuminated.
Posts: 831 Likes: 23
Posts: 831 Likes: 23 |
Rocker switches. Try Export MGB to USA and Canada late 70s. That’s where I found mine for a 1980+8. The illuminated kind.
1980 +8 Blue And a few others ---------------- Stephen
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
The 76 facelift MGB had revised illuminated rocker switches.
Then in 1980 with the advent of mandatory fog warning lights, BL had to add a switch into a spare space, but the new switch didn't match. It was not so shiny and better made. So there are at least two versions.
