10 members (James B W, Hamwich, IcePack, Luddite, JohnHarris, Ncik P, John V6, RichardV6, JMcL, DazMog), 259 guests, and 71 robots.
+8Rich 77
Topics49,870
Posts837,672
Rudolf
When the heater fan switch on mine broke the closest I could find to replace it was from Holdens, code 020.034
Heater Fan 2-Speed Rocker Switch
The only differences between it and my original were the icon and the fact the new one was illuminated.
Curiously, although none of my existing switches lights up, I found the loom had an unused spade connector which I plugged in and it worked! So now when the Morgan headlights are on the heater switch alone glows on the dashboard. I expect one day I will replace the other three switches with newer illuminated ones.
~iw
2011 Morgan 4/4
1932 Austin 7 Chummy
We always knew you were illuminated.
Best Regards
Lang may yer lum reek
Rocker switches. Try Export MGB to USA and Canada late 70s. That’s where I found mine for a 1980+8. The illuminated kind.
1980 +8 Blue
And a few others
Stephen
The 76 facelift MGB had revised illuminated rocker switches.
Then in 1980 with the advent of mandatory fog warning lights, BL had to add a switch into a spare space, but the new switch didn't match. It was not so shiny and better made. So there are at least two versions.
