6 members (Rex_tulips, Brian G, Nick55, Mog on Island, Tweed19er, TBM), 416 guests, and 41 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,346
Members9,215
#576666 15/05/19 01:39 PM
sarnia Offline OP
I have a 1994 Morgan 4/4 with 1800 Ford Zetec with milage of 21000.
It has always had a very hard to press clutch pedal, but lately seems to be even harder. ( It may be my age). The clutch is cable not hydraulic, I have lubricated the pedal box and wonder if it could be the cable being worn. If I don't fully press the clutch pedal sometimes I can crunch the gears. Any advise would be appreciated. Regards Sarnia
Hi Sarnia,
I had exactly the same issue when I bought mine a few years ago. I went for the pedal box, over-greased every possible part of the system to zero effect. In my case it all came down to an originally badly guided clutch cable of more than a a meter which went all the way from the drivers side (left on my car) passing far in front of the sump to the bellhouse clutch fitment on the other side. That long and wobbly cable eventually wore out until the clutch pedal showed the symptoms you describe. I went through some very poor attempts by a local garage to fix it- resulting in a general overhaul of the gearbox, a new clutch set a.s.o. I learned quite something about Morgan mechanics over a few months.
In hindsight a new, shorter, properly guided clutch cable would have been the end of all trouble. My new shorter cable now runs behind the sump. Clutch works perfectly.
Cheers, Mich
4/4 1996 1.8 ZETEC Silvertop It has Swivel Pivots and an amazing Umbrella Holder!
Here's what I think may be happening.
The cars of this era that have a cable-operated clutch use a bell-crank type arrangement to transfer the thrust of the clutch push rod to the pull on the cable to operate the clutch. It is mounted low down on the forward face of the engine bulkhead just next to the brake master cylinder.
The bell crank comprises two arms arranged at 90 degrees to each other, the arms are brazed to the ends of a tube. Over time, the brazing weakens and the angle between the two arms reduces from 90 degrees. This has the effect of reducing both the mechanical advantage and the length of throw, causing the clutch to become heavier and more difficult to disengage.
The cure is to remove the crank, realign the arms to 90 degrees, and weld in a bit more stiffening.
The picture below is of my car at Kevin Vernon's, showing the beefed-up version that he did for my car when he put the new chassis on. The finger pointing at it belongs to none other than SpannerJuggler.
Thought I recognised those dainty fingers . Looks like a good mod from Kevin there Tim
Andy G
1999 +8 , Indigo Blue.
Rather than engineer a method of clutch release I opted for an internal slave system for My +8 Bitsa and ZETEC powered DHC. The downside of this is I must pull the engine/trans if I have problems with the slave. The upside is an easy design and by changing the size of the clutch MC I can very the effort required. Another downside may be cost???
Button
Those nails look far too clean to me..
Seconded on the swap to Hydraulic - Retroford do a kit for T5 box and also Type9/Rocket box.
They may be able to supply a kit for you:
http://www.retro-ford.co.uk/shop/content/type-9-rocket-hydraulic-clutch-release-bearing-kit-bc002
sarnia Offline OP
thankyou Mich i will try and purchase a shorter cable ,if i can find a supplier .thanks again. Sarnia
I've just remembered - that's actually my hand, Colin was taking the pictures. I was far too excited to remember to take any photographs myself.
Gone to Porsche
Gone to Porsche
Clutch Diaphram plate hardened, replace full Clutch Kit
