Topics48,352
Posts813,176
Members9,212
Posts: 152 |
Posts: 1,360 Likes: 5
Posts: 1,360 Likes: 5 |
Plus Four Bentley Velvet Red “Grandi P” Golf ehybrid thingy “Toadie” Polestar 4 “Vger”
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Looks very neat.... Up to what speeds do the magnets hold? I'm only asking for +8 owners.
+8 4.8
Posts: 671 |
Very clever indeed. What strength neo magnets did you use, I’d like follow your lead
Posts: 152 |
So far, the magnets hold at approx 110kmh. It also depends on wind conditions. I chose these magnet size also considering the aesthetics, as I didn't want to have there to big magnets. Might be, they will not hold at very high speeds. I am still experimenting, didn't try higher speeds. On the other hand, when raining, I seldom drive at high speeds. The quadratic magnet is 5x5x5mm and holds around 1,5kg. The round one has a diameter of 10mm and holds also around 1,5kg. The bond I used is a 2K Bison Power Polyurethane Bond, as it is more elastic. Probably any epoxy bond will do.
If You are following with the plastic "stiffeners" described above, avoid any sharp edges, not to hurt the synthetic leather when imposing it. A bit silicone smear will facilitate it. Round both ends and inner edges.
Posts: 671 |
Posts: 152 |
Just tried higher speeds - the magnets are to weak for speeds higher than 110kmh. In some places there was a strong wind, they then did not keep even around 100kmh. So, the magnets should be stronger. However, they will be larger.
Posts: 5,108 Likes: 56
Black Rat Charter Member
Posts: 5,108 Likes: 56 |
Just tried higher speeds - the magnets are to weak for speeds higher than 110kmh. In some places there was a strong wind, they then did not keep even around 100kmh. So, the magnets should be stronger. However, they will be larger. Try driving with the hood down you won't need any magnets
Posts: 7,066 Likes: 21
Posts: 7,066 Likes: 21 |
Posts: 35,784 Likes: 471
Posts: 35,784 Likes: 471 |
Great work well done that man
