2 members (PaulV, GrumpyPa),
303
97
Topics49,847
Posts837,389
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
Thats good you not far away at all! small group of us on here(the Forum) go to The cafe at Blackbushe airport for breakfast meets when there's not much else going on.... always posted on here,
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
One issue with the 'new' MMC solution is that one of the lower mounts sits below the level of the undertray, around midway along the wheelbase. This can cause problems with ground clearance when traversing speed bumps.
Andy
Posts: 592 |
Blackbushe sounds perfect Skullmog; close enough to dash for home if someone spots a rain cloud mid Atlantic 😉
Thanks for the info Andy, as our local council have turned our village centre into a tank trap (obviously fearing an invasion of some sort) any reduction in ground clearance would see me restricted to my drive.
M3W Brooklands (2015) Moody 41 (2013)
Posts: 1,671 |
Re any welding reqmts - I can recommend Malcolm at speedweld - Farley Hill He can sleeve and support where needed. http://www.speedweld.co.uk
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
IMHO, in reality exhaust cracks are not the major issue. Grab another box of popcorn and read "Chassis Cracks - lower front Wishbone" and "Cracked & Bent Chassis" on this great Forum.
Be Safe good Sir.....
Posts: 592 |
Hello OZ 4/4, thanks for the link, i’m trying to work out what improvements my M3W has and doesn’t have. It’s 11/50 on the Brooklands spectrum which is quite an early number but it was first registered in 2015 which is very late. I can see I don’t have the gussets welded in on the lower wishbone joint which I thought happened in 2014? When I’m home at the weekend I’ll do a frame inspection to determine what stage of mods (if any) it was subjected to during build.
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
It looks like we might be meeting you at Blackbushe this weekend, we can go through all the chassis and various upgrades with you.
Posts: 592 |
Perfect, but don’t frighten the wife. 🤦♀️
Perfect, but don’t frighten the wife. 🤦♀️ 2014 onwards cars have the improved chassis, with the welded in brace behind the engine. The lower wishbone mount cracks have only appeared on earlier cars, mine was one of them as far as I know these haven't been seen on post 2014 cars as the tube wall thickness was increased on the vertical tube where the wishbone mount is welded.
Hello OZ 4/4, thanks for the link, i’m trying to work out what improvements my M3W has and doesn’t have. It’s 11/50 on the Brooklands spectrum which is quite an early number but it was first registered in 2015 which is very late. I can see I don’t have the gussets welded in on the lower wishbone joint which I thought happened in 2014? When I’m home at the weekend I’ll do a frame inspection to determine what stage of mods (if any) it was subjected to during build. Very worthwhile checking...
