0 members (), 222 guests, and 86 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 3 of 3 1 2 3
Gambalunga #577972 25/05/19 06:19 AM
Fit 5 link supension. You get a comfortable ride, panhard rod, and there is no need for anti tramp bars. Handling is improved as well.
You will never get a limousine ride with a Morgan because of the ancient chassis design an the limited travel but a 5 link suspension system will keep everything under control and optomise what you do have. Even Morgan went to a 5 link system on the ARP4.
+1, I can’t comment on any of the “cheaper” options, and if they work for you that’s great, but the 5 link suspension totally transformed my car. So much more positive cornering means less need to slow down, less crashing when you hit a pothole, and much more control during “spirited” starts.
SWMBO says it’s more comfortable which is an added bonus. The only downside as far as I’m concerned is the price.
Steve L.
1996 Plus 8
N22 MOG
Bonesie #578117 26/05/19 07:03 AM
Rog Offline
Originally Posted By Bonesie
Bump stops. Am I right in saying that they stop the springs bumping on the frame ? But the springs still bang onto the bump stops ? So they dont 'fix' a problem, they make the bump a bit softer?
Bonesie the term ‘bump stops’ may be a bit misleading. There Is no “bang”. They are more of a spring assister or secondary spring.
Roger
Bonesie #578131 26/05/19 09:54 AM
I had this problem with my 4/4. being as my doctor calls me Obese when i went over bumps, accelerated hard or on undulating roads the prop shaft the casing under the seat and went off like a machine gun. Very Disturbing.
The solution was to fit 4 seater springs and anti tramp bars.
unfortunately the factory only fitted one Anti Tramp bar on the drivers side.so at low speeds going over speed bumps the passenger side does tend to bounce.
so anti tramp and 4 seater springs have solved the issue.
The Car is fast the sky is blue just be safe in what you do
I also fitted Spax adjustable shocks all round which makes an overall difference to the cars ride and handling.
Page 3 of 3 1 2 3
