7 members (Pigiron, JohnHarris, Hamwich, Image, Bilymog, Vansrv6, Barkbark), 318 guests, and 23 robots.
+8Rich 92
Topics49,839
Posts837,302
TBM,
If you need any dimensions before you order just ask.
Yes, you have to shop around the Lotus dealers to find the cheapest, just like Morgan dealers I expect.
Cheers
TBM Offline OP
Originally Posted By John07
TBM,
Cheers
Thanks again, and not forgetting the 'Morgan Mark-Up' - replaced the indicator switch recently, Morgan wanted over £100, but a near identical genuine lucas one for a mini cost under £30.
Put a reverse and fog light on the back of mine - Morgan parts were about £40 each, got Land Rover equivalents for £3.75 ....
TBM Offline OP
And the Lotus one doesn't fit either. The collar is much bigger than the gearbox adapter.....
Getting VERY frustrated smile
Melvyn Rutter came back with a part number of BG2402/03 so will see what comes up with that.....
TBM Offline OP
Found one with the right number on the Speedograph site, so have ordered one (£120!!!!!).
In the meantime, saw on a TR site, where someone had replaced the flexi quill, with a solid one fashioned from an allen key which he ground square. He was providing them for other TR owners with good results.
So, armed with the old drive, I created my own and welded it up. So far it has survived the 25 mile trip to work. I've also re-routed the speedo cable - the original route had some quite tight bends, which may have been creating some friction. We'll see what happens....
TBM Offline OP
This is the MOST frustrating thing I have ever had to do in over 35 years of motor maintenance.......
Sent the Lotus one back.
Weld broke on my fix - not enough penetration. Pushed out the spacer washer, cover and circlip somewhere between here and MK making that unit un-repairable.
Collected Speedograph unit from Post Office. EXACTLY THE SAME DIMENSIONS/THREAD AS THE LOTUS ONE I JUST RETURNED.
However, as there doesn't seem to be a single person in christendom that knows the right part number/other model equivalent I have decided to order a new angle drive adapter (the bit that clips onto the gearbox with the Y bracket) from Lotus, so that will then fit the new angle drive perfectly.
So, for future reference:
Part Number for Morgan 4/4 1600 - known only to God
Part Number for Lotus Elan equivalent: BG2402/03
Part Number for Lotus Elan adaptor:FZZZ026Z (Paul Matty)
