6 members (Anonymouse, Gallanach, Barry M, Alan Patterson, nick w, Pittsartist), 262 guests, and 28 robots.
+8Rich 96
John V6 51
Topics49,900
Posts838,035
#578034 25/05/19 04:04 PM
kar120c Offline OP
Sitting on side of road. Engine just stopped. It’s so windy I can’t hear if fuel pump running. Car only has 500 miles on it. Do fuel pumps ever give up that quickly?
Phil
2013 Sport Blue/Black Leather
kar120c #578036 25/05/19 04:20 PM
They have been know to fail that quickly.
Check the reset button, around the lower right hand side of the oil tank, they have been known to trip unexpectedly.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
kar120c #578055 25/05/19 05:24 PM
Turn on ignition and check the battery voltage. When the current goes too low the electronics go blank and the engine just stops. Basically the Alternator/Rectifier was DOA. If the voltage is too low the fuel pump won't.
kar120c #578069 25/05/19 06:18 PM
kar120c Offline OP
Thanks - had it flat-bedded to garage since bad weather was on the way. Voltage is good. Still reading high even after multiple start attempts.
I'll check reset button later this weekend. I'll kick myself if that ends up being the culprit! lol
Thunderstorms just hitting where I was stranded so glad the Morgan and I are off the road!
Phil
kar120c #578079 25/05/19 07:06 PM
Car won't turn over if the reset tripped so... May the fuel pump. If you turn on the ignition and don't hear the whine of the pump then that is the likely culprit!
kar120c #578083 25/05/19 07:40 PM
If a 2013 car with 500 miles only: she was not moved much.
Check the tank and fuel lines for debris!
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
kar120c #578084 25/05/19 07:54 PM
Good to hear you are safe Phil. Trust you get this sorted soon on your 500 mile car
I was thinking the same.
kar120c #578107 25/05/19 11:05 PM
kar120c Offline OP
I couldn't stand it anymore, so I went over to the garage to test it. Hit the reset, then turned the key and the pump started. Hooray! Engine turned over a few times and caught and ran for a few seconds but couldn't rev it past 1500rpm, then stumbled and died. Totally silent - no pump. Hit reset again - no pump. Sooo, something is going on with pump or pump circuit. IIRC, the pump should run at all times so I guess it's time to start checking voltage through the circuit to make sure the pump is even getting power consistently. If it is, then it must be internal to the pump itself. Even if the lines are clogged the pump should be whirring.
Now I remember my Caterham ownership. Lots of stuff to diagnose at first, then was pretty solid. Hope this phase doesn't last too long! smile
Phil
kar120c #578115 26/05/19 06:16 AM
The symptoms are those of a failed pump.
Check the fuel pressure at the test port on the top of the engine, it should be 58psi or thereabouts. The fact it won’t rev beyond 1500 points to low fuel pressure
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
