6 members (Rudolf, Moggo, Alan Patterson, John Winn, John V6, High Hamster), 244 guests, and 59 robots.
+8Rich 101
John V6 58
Topics49,911
Posts838,154
Georgetoad, woolfie
TimG #578158 26/05/19 02:23 PM
Originally Posted By TimG
Bearings can be affected by brinnelling. Brinelling can be caused by a heavy load resting on a stationary bearing for an extended length of time.
As the S&S x-wedge uses plain shell bearings for both mains and rods, I can't imagine this would be an issue. The issue you describe is much more likely with ball bearings due to the high point loads involved.
Late 2012 M3W
That makes sense.
Sportster engines do not like sitting for long periods. Bearings can be affected by brinnelling. Brinelling can be caused by a heavy load resting on a stationary bearing for an extended length of time. The result is a permanent dent or "brinell mark".
If possible turn the engine over occasionally & move the car if on its wheels or turn them if jacked up.
“Sportster” engine ???
I think he meant “Sportster, engines .....” he was really to someone with the screen name Sportster rather than reffering to the Harley 😄
The comma was missing
Cheers John
2011 4/4 - "Elrond"
2007 Elfin C3 Clubman - “Gimli”
Lightspeed I think you mean babbit bearings. Brinnelling affects roller & ball bearings. The bigger & heavier the engine more likely to be affected. Very large engine may have a mechanism to bar them over occasionally or even keep them turning very slowly.
Ken the post was in response to Sportster.
TimG #579000 31/05/19 01:57 PM
You are correct, I did mean Babbit Bearings, darn Autocorrect on the phone and bad glasses keep me from catching thing quickly. Once on the big computer then all usually goes well.
