I've not had any trouble yet with blown fuses, but in the interest of using more modern, easily available fuses I've been thinking about replacing the two fuse blocks on my Mog with a modern fuse block. The modern fuse blocks I've seen advertised seem to require a common bus, which I don't think is used with my Mog. Has anyone done this? If so, what fuse block(s) did you use?
danbee, Toronto
Wotan
