9 members (PaulJ, Mogdavid, hugo, mph, David Preston, DCH, Willowgreen320, KennethM, Steve +8),
286
Posts837,972
Posts: 180 |
Hi, I am getting a bit fed up with the lousy rear view mirror on my S1 (which I believe is the Librands replacement type), which even at maximum articulation gives me a great view of my folded hood, but not the road behind me. Has anyone had a better results & field of vision with any they have bought elsewhere?
Posts: 469 |
I had a librands on my S3, the first librands had the wrong arm on (the piece from the mirror to the windscreen) it would not tilt far enough to see down the road, the correct one was sent out immediately, apparently it is slightly different to the trad type, could it be possible you have the wrong one??
2017 Mercedes Benz SLC 200 AMG. 2019 Mercedes Benz GLA 200 AMG Now Ex-Mogger!
Posts: 180 |
Exbiker
Thanks for your reply. That is interesting, perhaps I do have the wrong one. I might try a new Librands unless anyone on here has an alternative to recommend
Ian
Posts: 1,079 Likes: 71
Posts: 1,079 Likes: 71 |
I use the morgan mirror after the plastic OE mirror broke. Despite being smaller seems to work well and looks good. Morgan interior mirror
David Aero S4
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
I use the morgan mirror after the plastic OE mirror broke. Despite being smaller seems to work well and looks good. Morgan interior mirror I have this one fitted too and can confirm it works well...... James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I use the morgan mirror after the plastic OE mirror broke. Despite being smaller seems to work well and looks good. Morgan interior mirror I have that one on the Plus 8. It is fine.
Posts: 180 |
Thanks for the suggestions, I'll give the AR one a try
