Topics49,871
Posts837,677
Posts: 1,155 Likes: 2
Posts: 1,155 Likes: 2 |
I have been thinking my steering was a little wayward this last few weeks but after a long drive with the club on Sunday it was definitely worse so I decided to have look as the memsahib was in and could waggle the steering white I crawled under to have a look. It would appear that the two centre bracket bolts have worked lose on the steering rack!!! lock tab in place so I cant see how. So now a job to tighten them , I hope that the plate or bolts are not warn,if so are they available? My car is a 3.7 Roadster with Power steering and has done 11,000 miles and is 30 months old so not high miles ,has anyone else had this problem.
Posts: 37,436 Likes: 981
Posts: 37,436 Likes: 981 |
Your fault has come up on here before. Here is a gomog link steering rack
Thanks ,yes in to that just wo dered if the parts are available.
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
I have a spare bracket if you get desperate.
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
Thanks ,yes in to that just wo dered if the parts are available. I got my lock tab off Williams, they kept stock in When replaced I used locktite on the bolts and made sure the locking tab was securely folded, then a dab of paint to act a as simple tell-tale for quick future inspections
Posts: 305 |
30 months old ,would it not be covered by warranty ? Should the slack or worn bolts been checked when the car was Serviced .
Jimmy 2015 4/4 Sport Green 2018 VW Tiguan 1969 Morris Minor Traveller 1960 Morris Minor Saloon
Posts: 27,817 Likes: 749
Posts: 27,817 Likes: 749 |
It is on the service check list
Posts: 1,520 Likes: 60
Posts: 1,520 Likes: 60 |
Your fault has come up on here before. Here is a gomog link steering rack Reading through this gomog advice I dismantled these links some time ago and replaced the centre link bracket even though it showed no sign of failure. White marked all the fastening and often check them.
Your fault has come up on here before. Here is a gomog link steering rack Reading through this gomog advice I dismantled these links some time ago and replaced the centre link bracket even though it showed no sign of failure. White marked all the fastening and often check them. A good tip.
Posts: 263 |
30 months old ,would it not be covered by warranty ? Should the slack or worn bolts been checked when the car was Serviced . 30/30 (30 months or 30,000 miles) I think is the warranty. Mine runs out tomorrow, expecting to find mine fallen to bits tomorrow when I open the garage.
2017 Metallic Black +4 GDI
