5 members (Clipper, Davetherave, MartO, TBM, vincentvg), 295 guests, and 89 robots.
+8Rich 79
Topics49,871
Posts837,682
Rudolf
MR11MOG Offline OP
I have been thinking my steering was a little wayward this last few weeks but after a long drive with the club on Sunday it was definitely worse so I decided to have look as the memsahib was in and could waggle the steering white I crawled under to have a look.
It would appear that the two centre bracket bolts have worked lose on the steering rack!!! lock tab in place so I cant see how.
So now a job to tighten them ,
I hope that the plate or bolts are not warn,if so are they available?
My car is a 3.7 Roadster with Power steering and has done 11,000 miles and is 30 months old so not high miles ,has anyone else had this problem.
Peter.
Aero plus8 50th Anniversary.
Your fault has come up on here before. Here is a gomog link steering rack
MR11MOG Offline OP
Thanks ,yes in to that just wo dered if the parts are available.
Peter.
I have a spare bracket if you get desperate.
I got my lock tab off Williams, they kept stock in
When replaced I used locktite on the bolts and made sure the locking tab was securely folded, then a dab of paint to act a as simple tell-tale for quick future inspections
30 months old ,would it not be covered by warranty ?
Should the slack or worn bolts been checked when the car was
Serviced .
Jimmy
2015 4/4 Sport Green
2018 VW Tiguan
1969 Morris Minor Traveller
1960 Morris Minor Saloon
It is on the service check list
Reading through this gomog advice I dismantled these links some time ago and replaced the centre link bracket even though it showed no sign of failure. White marked all the fastening and often check them.
Graham
Octogenarian - (83)
1.8 4/4 Ivory
Toyota Yar.
VolvoV70
A good tip.
Serviced .
30/30 (30 months or 30,000 miles) I think is the warranty. Mine runs out tomorrow, expecting to find mine fallen to bits tomorrow when I open the garage. hide
2017 Metallic Black +4 GDI
