Topics49,908
Posts838,116
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
A question about brake pads to Elise Drivers. I have EBC yellow stuff but they howl and scream so that I wake all the neighbors. Also my ears suffer a lot from it. And you can literally see them wear out after every tour. What is a good alternative. It's a 2007 Toyota Elise. Thanks for recommendations.
Posts: 83 |
mintex 1144 were recommended by a Lotus indy. they've worked well for my spiritedly driven road Elise, quiet, progressive and work fine from cold. i do use yellows for my track car, and they're fine too tbh. sometimes noise can be caused by lack of copper grease or poor shims. can be random.
+4 since Aug 2012. Elise S2 Beetle '74 GT86 Mini Cooper MX5 (track)
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
Not the same but for feedback from a Caterham friend.
He went to EBC Yellow and had similar problems. They re-seated the discs calipers and gave it a good greasing and most of it went. He also had the issue where it wore his discs out faster but he has a 30lb right foot. He does track the car and so they get hammered all the time.
I have the EBC Yellows on the heavy ML63 and they did not squeal at all and I have a 20lb right foot. They also wore the discs out a bit quicker I expect so I have just fitted new discs and EBC Yellow and they are also not squealing.
I suspect Yellow's are just too hard for something as light as an Elise unless you are repeatedly hammering them.
I used to have Mintex in tuned road cars and never had a bad experience.
