9 members (Image, MartO, sprinty, Plus Four Guy, Alan Patterson, MartinB60, RedThree, Simon, AMorgan), 210 guests, and 99 robots.
+8Rich 78
Topics49,872
Posts837,686
Rudolf
Originally Posted By Craig Jezz
Originally Posted By SteveT
Craig, to do it properly you need to part the joint and apply the paste on the inside of the pipe. I can't see applying paste from the outside doing anything. Of course you could wrap it and use a clip as you suggest but it's a bodge and will look like one. Sometimes the joint is 'sprung' and once you loosen the u clamp it opens up a bit so you might need to push the two together as you tighten it. If that makes sense. I've also found that the pipes can be too loose a fit especially if of different origins.. I've cut a thin strip from a coke can or similar to use within the joint as a fix.
Advice taken Steve 👍, I used an additional U bolt and a jubilee clip.
A bit late now as you have done the job but Mikalor clamps are better than jubilee and are what the M3W's exhausts are clamped with.
https://www.demon-tweeks.com/uk/mikalor-stainless-hose-clamp-245296/
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Heinz #582200 20/06/19 08:18 AM
Originally Posted By Heinz
My car does not look so pretty clean after our last Italy tour but you can see the pipe connections.
and the manifold
Heinz, I do like that manifold wrap, super neat job
