1 members (MartO), 325 guests, and 84 robots.
Topics49,847
Posts837,389
Page 8 of 10 1 2 6 7 8 9 10
Originally Posted by tmg513
Originally Posted by Edwin
My '65 +4 has never presented misty gauges.
Neither has my '72.
Neither has my 2016 4/4!!
Dark Red 4/4 80th Anniversary
Multiple holes drilled in the casings has all but eliminated misting.
I fitted a leather apron to the top of the dash which covers the gauges and keeps any water leaks out.
They misted in Scotland in the Grampians but that was extreme with heavy rain and hail. Roof down......
Using sidelights made no difference to mine.
My Plus 4 rarely shows any misting. Maybe a hint when the weather is really cold.
Originally Posted by madmax
Not sure why my gauges never mist up !
They are frightened to, due to your avatar name.
Best Regards
Lang may yer lum reek
TBM Offline
My old (1962) Land Rover dials were always misting up.
Only had it once on the Morgan - February, parked overnight in an underground carpark in Brighton. Soon cleared though.
My car is always parked outside with the hood off though, so there's not much variation in temperature.
Originally Posted by paddockman
To all those that have offered sound advice and guidance a quick up-date.
I've spoken to a Morgan Engineer regarding the engine performance. He has agreed there's an issue with the car and thinks either a wiring fault or early failure of an ECU or associated component that needs to be sorted at dealer level. So that is the next step.
Hopefully there will be some easily identifiable failure and I can move on getting to know the car
Cheers again for all the advice.
Paddockman, you mention in your first post your Mog is around 3 weeks old, I thought at 1 month or 1000 miles, MMC recommend the dealer checks over the car again, certainly mine did and at no cost (unless you wanted an additional oil change)
Hopefully you will get your engine / ecu issue sorted and fall back in love with your Mog
Glad to hear that the factory has acknowledged that there is a problem with the flat spot. I somehow doubt an ECU problem, unless someone has inadvertently loaded an incorrect calibration, or it would be happening across the range. If it was me I would be checking the things relating to throttle position first, the sensor on the pedal, the actuator at the throttle body, and then move on to other sensors relating to fuel air mix and so on. Let's face it, a naturally aspirated 2 litre engine is never going to deliver the low down torque of a turbo charged engine but it should pull well from from 2K on up with a gradually increasing push until it gets to somewhere between 3,5K and 4K at which point you should start really shifting.
I would not worry too much about the running in thing. We did 3,000 km just getting the car home so it's first service was at 3,000, and that didn't include an oil change. Most cars these days don't even get their first oil change until 20,000 km. The precision of fit and finish of mechanical components is much better than it was years ago when I first started mucking about with engines.
Good news on the flat spot engine front
I’m sure between MMC and a main dealer will sort it out
As to the misty gauges which always gets Mog owners excitable (maybe not), I don’t think there is a definitive solution
It’s the miracle of science sherlock
Warm air on inside of instrument meets cold glass causing condensation
Unless the instruments are vacuum sealed this is always going to happen if the conditions are perfect for condensation
The fact it only happens occasionally or not at all is because the conditions haven’t been met
I only get it when taking my Mog out from a reasonably warm garage on a very cold morning with the hood down so that the cold air chills the glass and the warm air inside the instrument condenses
Why doesn’t it happen in other cars?
Polycarbonate instrument glass which is warmer
Vacuum sealed instruments
Air conditioning
Not being exposed to large temperature gradients behind the dash and the cockpit
The dash not being exposed to moisture like a Mog
Some instruments might be better sealed than others
Some Mog owners might never drive with the hood down on a very cold morning
I personally love it when it happens as I can imagine what it was like trying to flying a vintage aircraft
I even tap the glass to make sure the gauge is working doh
If it’s happening an awful lot maybe the area behind the dash has been exposed to some excessive moisture, maybe some heavy rain, a rogue spray with a pressure washer or a washer leak
Just some thoughts
It is hard to believe the misting cannot be cured, I understand all the excuses about temperature differentials - yawn - but in all the years of flying in Tiger Moths all year round I never once experienced this phenomena, or in any other light aircraft for that matter.
It'll be interesting if Kerry can add some input on this one about older aircraft too.
I’m pretty sure by the 1930’s Smiths Aero instruments will have been hermetically sealed
So another case like the fastenings of Morgan building down to a price and not improving the quality that should be expected at the current price ranges.
