Swede, we should meet up and compare noises. *s*
The clonking sound might be slack in the belt being taken up. Alternatively a loose bevel box. Check for moving petrol tanks, too.
If it is a rattling sound check if the roll over bars touch the aluminium body. In mine it isn“t the petrol shut off valve that rattles.
Etc, etc....
It is when your car is quiet you should worry, then something probably fell off.
DocNik, you have had a tough run with your M3W so I hope its all sorted now...
