6 members (nestor59310, Ruut Bianchi, MATTMOG, Supermog, BLUE+4, GrumpyPa), 232 guests, and 42 robots.
+8Rich 101
John V6 59
Topics49,912
Posts838,160
Georgetoad, woolfie
#586853 23/07/19 06:31 PM
RBW Offline OP
Evening everyone,
I have had enough of the "leather" peeling off all over the place on the underside of the dashboard.
I plan to drop the panel, remove the covering and spray paint it black.
I am unsure what metal it is made of, I presume it is steel, but could it be aluminium?
Does anyone here know for certain?
Many thanks
Rylan
2015 Yellow +4
A magnet will soon tell you conclusively.
To the best of my knowledge the Dashboards are made of multiplex with a layer of veneer.
What leather and Metal?
The underside panel of my dash is plastic!
Mark - No Longer driving
It's ally assuming it's the same as I had on both my plus 4's. I'd be tempted to cover it in black vinyl.
2008 4/4 1.8 Duratec
RBW Offline OP
I have a magnet on the way, I was hoping I could get a answer from TM, I am a bit impatient smile
Thanks SteveT, mine is covered in vinyl but its peeling all over the place and wont bond no matter what I try! hence the paint idea
2015 Yellow +4
Definitely aluminium. I'd be surprised if you used decent vinyl, a good contact spray adhesive and also wrap the edge a bit if it would peel.
Rog Offline
The stainless sheet metal panels on my car appear to be manufactured from non-magnetic austenitic grade frown
Roger
Rog, now you've said SS it's made me wonder, you may be right. Either way the under dash is thin sheet metal and not plastic!
Are we really talking about the dashboard or the plastic part beneath the dashboard?
I kept the RHD dashboard of my then P4SS as a souvenir when it was converted to LHD. It's definitely multiplex.
