0 members (),
313
89
Topics49,870
Posts837,667
Posts: 513 Likes: 2
Posts: 513 Likes: 2 |
So I left my 2012 plus 4 parked in the sun yesterday for perhaps 30 mins. It was pretty hot... over 30 degrees where it was sitting I'd say. Came back to start it and the rev counter went to full deflection and stayed there. Switched off and on and the rev counter stayed at 0 even after starting. Switched off and on and went to full deflection even after starting. Switched off and on and zero. Switched off and went and left it 5 mins. Then back to normal. Switched off in garage after driving home and i haven't dared to look at it again yet.....
Anyine else had ghis?
Thanks Nick
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
I haven't but I think there were some posts years ago on this.
Posts: 2,093 Likes: 74
Posts: 2,093 Likes: 74 |
Recall most advice given here in the past relates to ensuring a slight delay between switching on ignition and actually starting the engine. This gives time for ecu to sort itself out. Suggest a delay until fuel primimg sound stops, speedo has jiggled around (as it does if you watch closely) and settled to zero and immobiliser light gone out. Sounds a lot but only a few seconds in practice.
True Deejay I also understand it lets the ECU settle down.
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
That is the procedure I have always followed and, touch wood, it seems to work.
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Mine has done similar, and I was advised on here to turn the key with the ignition lights on only for approx 10 seconds before turning the engine over. Something to do with the ECU
No further issues for me
I hope this helps
Craig Jezz
Posts: 541 Likes: 7
Posts: 541 Likes: 7 |
Recall most advice given here in the past relates to ensuring a slight delay between switching on ignition and actually starting the engine. This gives time for ecu to sort itself out. Suggest a delay until fuel primimg sound stops, speedo has jiggled around (as it does if you watch closely) and settled to zero and immobiliser light gone out. Sounds a lot but only a few seconds in practice. Agreed, mine has done this on 3 or 4 occasions and this always sorts it.
Posts: 513 Likes: 2
OK many thanks folks - I'll try that first....
Posts: 1,711 Likes: 1
Posts: 1,711 Likes: 1 |
My speedo does this, it takes a while for it to settle down, must try the delayed start trick. I have a Omex ecu in so this could also be the issue.
Graeme: 2011 +4
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Recall most advice given here in the past relates to ensuring a slight delay between switching on ignition and actually starting the engine. This gives time for ecu to sort itself out. Suggest a delay until fuel primimg sound stops, speedo has jiggled around (as it does if you watch closely) and settled to zero and immobiliser light gone out. Sounds a lot but only a few seconds in practice. I was told this by the Ford Regional Service Manager, when I had a recurring problem on a new Fiesta, a few years ago. He advised me to wait until all the check lights had gone out, before starting the engine. It solved the problems on the Fiesta and it is now habit for me on my 4/4 and my current tintop.
Bud 4/4 "Stanley"
